Post by wutno on Aug 26, 2015 23:55:42 GMT -5
So I was poking around in my CVT for the first time and there's a pickup coil (same as used for the stator) in there, it has a cut wire on it so it's not doing anything, what purpose would this have served?
Post by spaz12 on Aug 26, 2015 23:58:20 GMT -5
Interesting.... You must show us pictures please!
Post by wutno on Aug 27, 2015 0:05:30 GMT -5
Give me an hour and I'll take it apart but from what I remember there was a bump on the clutch bell and it was mounted to pick that up? But I don't know where the wire originally went. Here's a pic of the coil itself, I'll have to take the CVT apart in a bit to get a pic where it mounted, etc.
Post by spaz12 on Aug 27, 2015 0:21:55 GMT -5
That's a pickup coil for sure. It certainly has no business on the cvt side of the motor though. Someone placed it there I'd bet and forgot about it.
Post by wutno on Aug 27, 2015 0:25:04 GMT -5
There certainly was mount points for this guy, but the wire was just hanging out of the CVT cover (always wondered what the wire was), I can't think a dealer would just install random hardware though. The CVT cover is actually embossed with the dealers name on it.
Post by spaz12 on Aug 27, 2015 0:30:27 GMT -5
Then ya got me stumped. I have no idea.
Post by wutno on Aug 27, 2015 3:20:48 GMT -5
Rune 75
Post by Rune 75 on Aug 27, 2015 4:40:26 GMT -5
It's used for monitoring the backwheel speed, and cutting the ignition when the maximum set speed is reach. It's a pretty common restriction actually. It restricts speed not engine rpm.
Post by wutno on Aug 27, 2015 4:50:26 GMT -5
The more you know! Thanks, seems that the previous owner cut it at some point then.
Post by Fox on Aug 27, 2015 4:53:38 GMT -5
Yep! Rev limiter. I have never seen one in person but I read about and saw a picture (below) of one on a scooter in England at least 8 years ago on another forum. To negate it you would simply remove it or just cut the wire and leave it. I assume the wire ran to the CDI and I assume you are also in the U.K. or Europe. I save any and all interesting pictures I see. Thanks for the pic of the clutch bell with the reluctor on it.
Rune 75
Post by Rune 75 on Aug 27, 2015 8:27:38 GMT -5
Yes the wire runs to the cdi. If you hook it up whit a switch you can turn the restriction on and off as you please. That may come in handy.
Post by iwiketuddlz on Aug 27, 2015 10:45:25 GMT -5
It is very handy my current cdi has a rev limiter built In as well and I installed a hidden switch to flip it on when I go by coppers and such, also a good alarm kinda,we'll it won't let a thief get very fast anyway!!!
Post by wutno on Aug 27, 2015 14:49:31 GMT -5
g
Post by Fox on Aug 27, 2015 15:15:36 GMT -5
Fox Actually, Massachusetts. Interesting. I didn't think any stateside scooters had that restriction. What year is that scooter?
Post by wutno on Aug 27, 2015 16:45:56 GMT -5
g
