mikerenz66
Scoot Newb
Father of 4 boys, separated, disabled, just doin my best to raise my kids
Post by mikerenz66 on Aug 29, 2015 22:13:11 GMT -5
Is it normal for the model to have the small bulb light when ignition is on but engine is not running and running but the larger bulb S2 35/35w will only light when the engine is running and switch is on high beam. I am guessing that the larger bulb does not have a dual element for high and low beam. Any help thanks
Post by katastroff on Aug 30, 2015 5:39:04 GMT -5
Seems pretty normal to me. Hi and welcome.
Post by scooterpimp on Aug 30, 2015 10:06:00 GMT -5
You got it! the little bulb is a pilot light & other is actual headlight. Which is ac powered (on when running)
mikerenz66
Scoot Newb
Post by mikerenz66 on Aug 30, 2015 12:04:08 GMT -5
Thanks for the welcome. The larger s2 35/35watt does have 2 filaments. Only the unshielded (high beam) works but the shielded low beam does not. I had my son whom works as a electrical/mechanical engineer check the bulb and connections. He told me the 3 wire connection blue,green,white has a short to ground. What would be the fix?
Post by Fox on Aug 30, 2015 12:26:02 GMT -5
Welcome.
Post by scooterpimp on Aug 30, 2015 21:42:16 GMT -5
Most common headlight issue is the bulb. , i usually carry a few spares in the garage. Sometimes bulbs last for years , sometimes they last 2 weeks.
