Post by stoneforth on Sept 11, 2015 23:57:05 GMT -5
I don't have any idea on how to hotwire but all my scoot has for protection is a single wire on the cdi that sends the spark to ground. It's a really silly design. I'm thinking of installing the cdi in the seat instead.
Post by FrankenMech on Sept 12, 2015 1:22:09 GMT -5
I think I could have got him down a bit more.Good find! Yeah, they should have given him $20 just to haul it away because of the missing parts. You can't expect people to work for free.
Post by birdman on Sept 12, 2015 4:43:55 GMT -5
very nice find
Post by renagade281 on Sept 12, 2015 9:40:10 GMT -5
I think I could have got him down a bit more.Good find! lol
Post by renagade281 on Sept 12, 2015 9:50:00 GMT -5
now my next question is..... how much of a headache would it be to take the 150cc motor off of this and put it on my 50cc jonway?
Post by Fox on Sept 12, 2015 12:14:03 GMT -5
Easier to swap the vin plate.
Post by renagade281 on Sept 12, 2015 14:08:49 GMT -5
Easier to swap the vin plate. lmao true ... basically which parts are interchangeable tho? im sure the carb isnt since it says pd24j or something..that would be too big right?
Post by aeroxbud on Sept 12, 2015 14:31:15 GMT -5
Nice score
Post by Fox on Sept 12, 2015 15:05:43 GMT -5
Well, the electrical issue would be the stator plug connection. I have swapped stators from a 50 to a 150cc before (8 coil)
The other issue is the engine mounts. On a 150cc they are on the top of the engine whereas the 50cc has them on the bottom front so you are going to have to do some cutting/welding/head scratching etc... but it can be done.
The flywheel puller needed for the 150cc is a 27mm x 1mm left hand thread. It screws in reverse.
The 50cc's use a 24mm x 1mm right hand thread
You can use either an 835 or an 842 belt on a long case 150cc.
