Post by 2001eton on Sept 28, 2015 17:57:21 GMT -5
Ok so i have no spark.. But im getting a 12 volt reading from a test light from the wire going to ignition coil. Got a new ignition coil no spark.. Its i belive a 2001 eton beamer
Post by 2001eton on Sept 28, 2015 17:59:35 GMT -5
Post by spaz12 on Sept 28, 2015 18:04:35 GMT -5
That's definitely a DC cdi in the E-ton. What are your voltage readings from the pickup coil?
Post by 2001eton on Sept 28, 2015 18:06:15 GMT -5
Pick up coil?? But if its dc shouldnt there be only one wire? In the 2 prong? Section.. And i also read a dc needs a battery but i had it running with out a battery. See my confusion??
Post by 2001eton on Sept 28, 2015 18:06:46 GMT -5
I was just useing a test light
Post by spaz12 on Sept 28, 2015 18:14:52 GMT -5
The blue wire with a stripe (white?) is your pickup coil wire. Negative lead from tester goes to ground and positive to the blue wire. I'm pretty sure it's AC voltage for the pickup coil.
And you have me stumped on how you had an 01 E-ton beemer running with no battery. I'd swear that it's a DC cdi.
Post by 2001eton on Sept 28, 2015 18:18:55 GMT -5
The blue wire coming from the stator im getting the volt light on ... The only issue i had was when u hit full throttle it would bog out so i got a new carb but now i have a spark issue
Post by spaz12 on Sept 28, 2015 18:19:16 GMT -5
I just looked to see if there is a manual here, and I don't see one. Maybe someone else will know more? I've worked on two beemers and both had DC cdi's.
Oh, I think that there is a switch in the kickstand! It's been a few years so I really can't remember if it was that scoot that has one?
Post by 2001eton on Sept 28, 2015 18:20:11 GMT -5
Switch in the kick stand?
Post by spaz12 on Sept 28, 2015 18:20:40 GMT -5
Yeah, a safety switch.
Post by spaz12 on Sept 28, 2015 18:21:44 GMT -5
I think it has to be in the up position?
Post by 2001eton on Sept 28, 2015 18:23:25 GMT -5
Yea both way it starts up both ways it would bog.. But i just know i lost spark but if im getting the volt light at the wires for the ignition coil with a new coil shouldnt spark?
Post by spaz12 on Sept 28, 2015 18:25:51 GMT -5
Could be a faulty coil. I've seen it happen.
Post by 2001eton on Sept 28, 2015 18:27:14 GMT -5
Its brand new and i also took another coil i know works and riged it cuz the terminals were diffrent and that still didnt work
Post by spaz12 on Sept 28, 2015 18:35:10 GMT -5
Then you'll need to get a multi-meter to figure out what's going on. A test light will not give you your answers. I'm pretty sure that someone else here will also give you the values that you are looking for, because off the top of my head, I do not know them. Sorry that i can't be of more help.
