Post by renagade281 on Sept 29, 2015 22:06:24 GMT -5
So this guy does not have this hole blocked off from the valve cover and it is loud as hell. If I cover it with my finger it is quiet as a mouse. My question is what would be a good way to plug that. Should I weld a little plate over it?
Post by spaz12 on Sept 29, 2015 22:55:16 GMT -5
A blocked off rubber hose would be simpler
Post by renagade281 on Sept 29, 2015 22:57:21 GMT -5
well there is no nipple to put the hose on...thats what i would have done if i could
Post by ams417 on Sept 29, 2015 22:57:36 GMT -5
What diameter is the hole? Amazon has an assortment of expandable rubber plugs. Dorman makes them.
Post by renagade281 on Sept 29, 2015 22:59:31 GMT -5
nah im not gonna order a plug.. i will probably just weld a plate over it
Post by ams417 on Sept 29, 2015 23:00:56 GMT -5
Just break a stick off in it. It's just a 4T.
Post by renagade281 on Sept 29, 2015 23:03:01 GMT -5
Just break a stick off in it. It's just a 4T. lmfao im dyin off that one
Post by ams417 on Sept 29, 2015 23:10:38 GMT -5
Just break a stick off in it. It's just a 4T. lmfao im dyin off that one I was hoping you'd see the sarcasm. I once used metal expoxy to hold in a stripped out spark plug in the head of my Yamaha IT 175. It blew the plug out and I wasn't done riding for the weekend. It lasted several months until I put a new head on it. I'm good at fixing stuff right, I'm also good at fixing stuff right now.
Post by Deleted on Sept 29, 2015 23:29:07 GMT -5
Just break a stick off in it. It's just a 4T. Hey! At least we don't need no stikin' oil in our gas, ha ha. Bill
Post by katastroff on Sept 30, 2015 4:17:01 GMT -5
Unscrew the little plate, make a rubber gasket the same size as the plate but with no hole in it, screw the contraption back on.
You might have to use longer bolts.
Post by Fox on Sept 30, 2015 11:04:02 GMT -5
You make a steel plate with two holes drilled in it. You'll need a gasket for it. You can get a variety pack of sheet gasket material at the auto parts store. Charge the customer for it. This one is fancy This one is not but it works and that's all that matters.
