I need help analyzing my engine sound.
Before sme background info;
I had a MJ #94 in my carb and when driving with WOT I could hear a light *ziiiiiing* sound.
I read somewhere here in the forum that that means it runs lean so I thought since the temperatures anyway are dropping recently I'll go up to MJ #96.
Now I don't have that *ziiiiiing* sound anymore but what happens is following;
When I cruise around I can hear some sort of "brabrabrabrabrabrabrabrabrabra" you know the engine sound like the piston is going forth and back.
Now when I crank it full to WOT for 10-15 seconds and release the throttle this "brabrabrabra" sound is gone and I hear.......nothing...or maybe
some sort of *vvvvvvvvvvvvvvvvvv* like it is driving in an empty/neutral gear. then i quickly apply throttle and release it again and the "brabrabrabrabrabra" is back.
Is this normal? Or is this some sort of a sign that I need to take serious? If so what could be the cause of this?
I hope what I just explained makes sense. Kinda hard to explain in words.
