Post by Fox on Oct 18, 2015 15:50:15 GMT -5
Try uploading it straight from your computer to the forum by clicking on "Insert image"
nehmo
Post by nehmo on Oct 23, 2015 18:15:58 GMT -5
Sorry I took so long. I didn't realize there was a page 2 to the thread.
Post by Fox on Oct 23, 2015 23:34:50 GMT -5
Yeah. That plug that goes to nothing is a standard feature on most scooters. Ignore it. Glad you got your scooter running well. As for that timing mark viewing plug, I'll go you one better and say that you don't even need to look at the T mark. All you have to do is line up the cam in the proper position and you are good to go. I use a socket on the fan through the hole in the shroud to rotate the engine to line up the cam. There are guys that will tell you this is wrong because the piston may not be at TDC but I can assure you it doesn't make a difference.
