Post by Fox on Nov 7, 2015 23:07:39 GMT -5
ahh,, if that's the case , if it works ok, i will leave it alone.. Yep! If it works don't fix it. A spare petcock is on my list of parts that every owner should order and put on a shelf for when their original fails. Instead of posting how your petcock failed and you ordered one, you can post how you replaced it immediately with the spare you already had. Other parts that are nice to have on hand for spares or testing purposes: Belt Rollers/back plate guides Brake pads/shoes CDI Coil Flasher relay Starter relay Stator 2 bulbs of each type
