Post by spaz12 on Jan 3, 2016 20:18:05 GMT -5
Scooters aren't safe in this town. Even in gated communities. I had three chains on one of my scoots and they cut all three. Luckily the center stand was locked down and they couldn't push it. Sadly, if it's outside and they want it bad enough they are going to get it.
Post by Dj Chocolate on Jan 6, 2016 1:08:27 GMT -5
i sometime get that if i don't let my bike idle enough or leave it on choke for a extra 20 seconds if ur using normal spark plugs and normal coils where you have poor electric spark could cause that speaking from experience i changed it to iradium needle plugs and orange ignition coils giving higher voltage could use carb n choke cleaner to clean out you carb thats what i use and i spray in all the holes with the straw that comes with the can!
Post by kagetenshi on Jan 12, 2016 0:21:42 GMT -5
Have you tried adjusting the needle settings inside the top of the Carb?
