Post by scott7 on Jan 26, 2016 21:27:32 GMT -5
Starting to do what? ,stalling out ? Please clarify . Does it start right back up?
Post by sumo210 on Jan 27, 2016 9:55:45 GMT -5
to stall out whatever reason it seems to just act like it ran out of gas.. but i know it has almost a full tank.. and it really only happened about 10 mins after i put new gas in..but i use premium e/i91 and above could that also be it?? i use premium because it so cheap right now its only 1.90 or so..
Post by scott7 on Jan 27, 2016 14:03:33 GMT -5
That's what your supposed to use is premium , not supposed to use regular gas it will ruin the engine.
Post by sumo210 on Jan 28, 2016 9:38:06 GMT -5
My understanding is that using regular is what ur supposed to use because the differences of how china and the U.S. rates the Octane is a difference of about 20-30 points so it would normally be regular..so im not sure about it but either way im not sure what it can be because it driving great in the cold but later in the day it starts to stall. Any ideas
Post by sjfishon on Jan 28, 2016 11:39:57 GMT -5
i have 2 of them, never seen a engine so sensitive on fuel setting. when they were new, one had a defective carb, the dealer swapped for a new one . it has the fuel adjust screw. the other is stock, and cant adjust. it is set rich, it will also kill if you gun it just a little. i have learned to turn up the idle to compensate. i don't like the idle this high but it is a cure. the one i can adjust i have dialed in, and you cant kill it if you tried. if you cant find any problem. get the fuel screw out an slot it so you cad adjust, or turn up the idle.. steve and----------
Post by sumo210 on Jan 28, 2016 12:18:24 GMT -5
thats what i did i adjusted the screw a bit but im waiting to see how it does today when i get home from work..
Post by sjfishon on Jan 28, 2016 12:23:05 GMT -5
which one,, idle or fuel air? did you adjust, hope you are lucky enough to have a screw to turn. steve
Post by sumo210 on Jan 28, 2016 12:37:09 GMT -5
i bought a "20mm" carb for ebay from some guy named starrider. so i adjusted the air fuel screw idk if its that same one i even adjusted the throttle a bit to see if maybe it would help is there another adjustment screw that i dont know about??
Post by sjfishon on Jan 28, 2016 14:12:49 GMT -5
sounds good, it just might be adjustment issue.
Post by sumo210 on Jan 28, 2016 14:51:01 GMT -5
im hoping so i plan on getting new jet just incase and a new filter just in case..
Post by scott7 on Jan 28, 2016 17:42:01 GMT -5
The higher the octane the slower the burn, that's what you want, if you use regular gas it burne quicker which may cause the air ,fuel to explode in the cylinder . This is called pinging . That what ruins the engine or piston. You want slow expanding burn. You said you put a bigger carb on . Is it a stock size cylinder? If so what size jet is in the carb, Mabey your getting to much fuel
Post by sumo210 on Jan 28, 2016 17:51:18 GMT -5
im not sure whatever it came with.. but im thinking on getting a new exhuast and a pod filter would that be able to compensate a bit for the bigger jet?
Post by scott7 on Jan 28, 2016 17:56:12 GMT -5
Yes , just make sure you get the air ,fuel mixture right. You don't wanna burn lean ,that's what makes it run to hot and will destroy the piston ,cylinder and Mabey the rest of engine. You should find the information you neen in the library tech on this site.
Post by sjfishon on Jan 28, 2016 19:10:30 GMT -5
you know if its to lean, if it bogs at half throttle'
Post by sumo210 on Jan 29, 2016 10:22:37 GMT -5
Thanks guys ill see what i can do thanks
