Post by sjfishon on Jan 29, 2016 10:57:12 GMT -5
if it completely stalling, i don't think its fuel related, but, don't forget, when you get gas, almost all stations now have the one pump, that you select the grade you want. if the person before you got regular, there will be well over a gallon, of that in the hose, before you get to the top grade that you selected,most stations have the valve at the tank; with a car and you get 15gal it wont matter ,but if you are only getting 1gal, it will, i keep a 5 gal in the garage just for the scoots. i take my car, pump say 10gal, then fill the 5gal, i use the middle grade says 90pluss, seems to work fine in all, like the boat motor mower ect.. steve i also put 1oz, of good old Gum Out carb cleaner in the 5 gal, have never had a carb problem.
