Post by 90GTVert on Feb 2, 2016 7:04:36 GMT -5
If the belt is pretty bad you'll see it. Could be frayed. Glazing on the sides isn't ideal, but common. Measure the width. You can find a service limit in a manual, but most Minarellis use about a 17mm wide belt. Preferably you want to stay within a mm of that. By 2mm less it definitely needs to be replaced.
Post by Fox on Feb 2, 2016 9:14:50 GMT -5
Here's an example of a worn roller weight There is a chance the previous owner used sliding weights. If so they look like the ones on the right. Sliders last longer than round weights.
Post by tiny on Feb 2, 2016 17:52:54 GMT -5
Nope that my friend is a worn out roller not a slider. Its not bad (I've seen worse) but it is defiantly your acceleration problem. A new set will fix that hesitation you spoke of.
Post by Fox on Feb 2, 2016 19:15:58 GMT -5
Nope that my friend is a worn out roller not a slider. Its not bad (I've seen worse) but it is defiantly your acceleration problem. A new set will fix that hesitation you spoke of. That pic was not the rollers in question. It's just an example for the original poster of this thread. I found it on Google.
Post by tiny on Feb 2, 2016 19:32:36 GMT -5
My bad sorry Fox
Post by johnwing on Feb 5, 2016 1:27:12 GMT -5
Thank you l'll check this weekend.
John
Post by manolis on Feb 8, 2016 3:54:33 GMT -5
Hello all. Take a look at www.pattakon.com/pattakonPatBox1.htmSee at the PatBox CVT: A guy modified his 50cc Honda Hobbit moped and now he "loves" it. Here is the youtube video he uploaded youtu.be/Ou3dBx-O-V4“January 10, 2016, mopedarmy forum, JBOT: Tonight I went to the store. Coming back I had to gun it uphill to catch the yellow. The bike just went uphill so fast compared to my other tune I had on it. It is nice to let the gearing do the work sometimes, and let the revs work other times.” Question? Thanks Manolis Pattakos
Post by tiny on Feb 8, 2016 16:56:54 GMT -5
Interesting
Post by 808ministroke on Dec 1, 2018 10:17:32 GMT -5
Post by 808ministroke on Dec 1, 2018 10:17:56 GMT -5
That cat is awesome!,,,
Post by 808ministroke on Dec 1, 2018 10:18:22 GMT -5
I meant t that cvt
