Post by pinkflames420 on Apr 10, 2017 17:09:27 GMT -5
Lol I think it's the plastic cover going around the enricher for protection of the wires. It flops around. No worries tho on the man. choke, if you happen to find something of course let me know please!
Post by knobby on Apr 10, 2017 17:23:03 GMT -5
Just digging around for a few minutes I found some needle type choke parts, but I really need one of those carbs here to be of real use. The little cable doohicky in the plastic bag may work using a hybrid setup with part of the stock assembly.
Post by pinkflames420 on Apr 10, 2017 17:34:37 GMT -5
Hm. I've seen those types online but they all mostly say for brand carbs. Is that a thread in piece ? Or would i slide into the metal bracket once I get it off my enricher? And the enricher doesn't have a thread in housing on my carb. I'm not sure how this would work. thank you for digging around for me...
Post by pinkflames420 on Apr 10, 2017 20:40:56 GMT -5
Has anyone been able to get this manual choke to work on there stock carb? I've posted a pic of my carb ^^^ I realize it doesn't have a needle tip,..Would this be essential for the conversion?
Post by AtariGuy on Apr 11, 2017 6:53:20 GMT -5
With some creative fab work i would assume one could replace the flat end choke with a needle end from your auto enricher? Just a thought.
Post by ryan_ott on Apr 11, 2017 9:14:29 GMT -5
Your easiest option if you needed a manual choke would be getting a $20 eBay carb with the manual mechanism, but you still need a cable and lever. So rob the brake cable and lever off that old bike sitting out back. www.ebay.com/itm/381013426493
Post by pinkflames420 on Apr 11, 2017 13:13:01 GMT -5
Your easiest option if you needed a manual choke would be getting a $20 eBay carb with the manual mechanism, but you still need a cable and lever. So rob the brake cable and lever off that old bike sitting out back. www.ebay.com/itm/381013426493 That is a good idea, to use the cable from the bike, but I literally had just bought a new cable and I hope to put some more kms on this carb before I upgrade! Atari, you have a good suggestion aswell... I think I WILL try and get that needle fabbed onto there! guess I need to do some more inspection on my carb. I will get back to how and if I get this one to work. Thanks !
