bogging
May 25, 2016 18:20:40 GMT -5
Post by bryank605 on May 25, 2016 18:20:40 GMT -5
my scooter is mostly stock jet upgrade from #83 to 85 the blue racing CDI and a cone air intake drilled exhaust, at first i could get the scoot to about 7600 RPM now the highest i can get it to go is about 7k and at full throttle it boges you can feel from 3/4 to WOT the drop in power what can i look at doing to fix this?
bogging
May 25, 2016 19:48:28 GMT -5
Post by bryank605 on May 25, 2016 19:48:28 GMT -5
I also just put on an A9 cam gained some top end lost my low end so I put in some 5 gram sliders and gain some low end back and now get to about 7300 rpm
bogging
May 25, 2016 20:23:33 GMT -5
Post by arkie on May 25, 2016 20:23:33 GMT -5
You could try even lighter sliders to increase rpm a bit. Best power if I'm not mistaken is between 7 and 8k.
bogging
May 26, 2016 8:19:46 GMT -5
Post by 90GTVert on May 26, 2016 8:19:46 GMT -5
bogging
May 26, 2016 8:23:32 GMT -5
Post by bryank605 on May 26, 2016 8:23:32 GMT -5
I just the 85 in sadly every single d I Roderick doesn't fit so I'm unable to adjust the idle mixture and I guessed at the 85 so I try a bigger one?
bogging
May 26, 2016 8:28:14 GMT -5
Post by 90GTVert on May 26, 2016 8:28:14 GMT -5
I would try larger jets and see what happens.
bogging
May 26, 2016 18:55:41 GMT -5
via mobile
Post by kagetenshi on May 26, 2016 18:55:41 GMT -5
Just for reference I run a cone filter and drilled exhaust on an otherwise stock taotao atm50-a1 sport(VIP future champion) and I have to run a #85 main jet and a #35 pilot at roughly 600ft above sea level. Not saying it will help, just as a reference point.
bogging
May 31, 2016 15:56:52 GMT -5
via mobile
Post by bryank605 on May 31, 2016 15:56:52 GMT -5
Well I now have a 95 main and a 38 pilot also tried a 90 main no improvement except now it pulses at idle
bogging
May 31, 2016 20:21:01 GMT -5
Post by arkie on May 31, 2016 20:21:01 GMT -5
A pulse is a sign of a lean condition. Check your seal on the intake. This can be done with carb cleaner or an unlit butane torch with the gas flowing. put it all around your intake and base seal. If the idle changes you found your problem.
bogging
Jun 6, 2016 10:38:30 GMT -5
Post by bryank605 on Jun 6, 2016 10:38:30 GMT -5
well i dont seem to have a leak and now i went back to stock 83 MJ and 33 IJ and stock cdi seems to run good again but cant pass the 7k rpm mark and seems to be bogging past 3/4 throttle
bogging
Jun 6, 2016 19:25:01 GMT -5
Post by niz76 on Jun 6, 2016 19:25:01 GMT -5
Bogging is an indication of a lean tune. That stock main jet is probably gonna be too lean with anything other than the stock air box...
bogging
Jun 6, 2016 20:30:59 GMT -5
Post by Deleted on Jun 6, 2016 20:30:59 GMT -5
Also, check for water in the fuel. Last year, during one of my tuning sessions (that spanned a few weeks) we had tons of rain for like 6 days straight. I took the scoot out and it was hard to start and bogged terribly. I went back to my original tuning and still had the same thing. Then, I checked my gas and, I had about a quart of water in my tank. (It came in through the gas cap vent which I now made a cover for)
Got rid of the water and drained the carb and everything was great again. Very easy to get water these days at the pump. Water leaks into the underground tanks through air vents and also through condensation on hot days from delivery trucks.
I am not saying this is your problem, you need at least a number 85 jet after losing the airbox, but this is an easy problem to check for and could save you a lot of effort. Pull the fuel line from the carb and drain some into a clear container. Let it sit for a bit and, if you see a separation layer, bubbles, or it is not clear, you have water.
Bill
bogging
Jun 7, 2016 14:00:14 GMT -5
Post by bryank605 on Jun 7, 2016 14:00:14 GMT -5
well i have check for already... and i did a plug chop with the 83 mj and it looks just right i'm not sure what else to look at when i put the bigger jets in it just pulses with no improvement and it just like it struggling to run.. i can get to about 6k to 7k rpms max and anything beyond 3/4 throttle just bog's down it pulls good on hills and takes off right away which is nice for going ac cross traffic but i sure seems like I'm losing my top end. and i got no improvement from the A9 cam i may just put my small BBK on (44mm) and see what happens
bogging
Jun 16, 2016 12:12:33 GMT -5
Post by bryank605 on Jun 16, 2016 12:12:33 GMT -5
well i got a 20mm carb and still having problem getting it past 6k RPM it will right away when i hit the throttle but after a few seconds it goes right back down to 6k
bogging
Jun 18, 2016 22:37:07 GMT -5
Post by bryank605 on Jun 18, 2016 22:37:07 GMT -5
Well I put on a 47mm BBK and I no longer have an issue rims now run all the way up to 9300k now I just need to get bigger jets
