Post by FrankenMech on Apr 17, 2024 6:17:02 GMT -5
Way too many colors in that room. Being in there for more than 10 seconds would give me a headache.
Post by milly on Apr 17, 2024 9:14:23 GMT -5
I like it FrankenMech, but then I am weird. I looked up the name of the village and it translates to Llan being church and gwryfon be the thousand virgin's. Saint Ursala and her thousand virgin's. Not even more than about 150 people there now.
Post by FrankenMech on Apr 17, 2024 11:04:07 GMT -5
That church would not hold 1000 virgins so they must have lived somewhere else. Must have been false advertising... -By the local pub.
Post by 90GTVert on Apr 17, 2024 13:06:33 GMT -5
I cut a head for a friend. He had a 50mm and a 54mm (actually 53.something). Both with no recess for the squish band/combustion chamber. He wanted one to match an old head with a .8-9.mm recess. I tried to tell him to check first then cut. He said just cut it and he'll check it later, rationalizing that the cylinder and piston look like the same heights as what he had before than needed the recessed head that he brought along so it should be the same with the new stuff. I tried to tell him that's flawed logic. I did at least convince him to leave the 54mm head alone and let me cut the 50mm to 54mm. He didn't realize I could do that. He had sent me a video showing someone cutting a head that was 20-30 seconds long. I've cut heads before on the lathe and using a drill as a lathe with just files to cut before that. I spent a good bit of time trying to at least come close to the angle of the squish band. He told me just cut it straight, it's fine. I cut it to match anyway. After a couple of hours to get it setup and cut, I said there you go... 10 seconds. Looks a lot easier on the internet. Finish isn't perfect, but it's me and a Chinese mini-lathe. The scratch on the original 54mm head is from me trying to check angle by running across it with a tool. I had a dial indicator setup on the tool post and then realized that I can't use it at that angle because the little lathe runs out of range. Setup a dial indicator to go against the carriage to measure how much I was cutting in to make it easier, but then it couldn't fit the space I had either. Came out OK in the end though. I then demonstrated a squish clearance check and gave him a piece of 1.57mm thick solder to use. He messaged me later that it didn't even touch the solder with the head that he wanted cut. I don't know what standard clearance figures are for a 125cc Dio build, but I told him probably 1-1.2mm would be fine just based on 2% of the stroke or so with a little margin for error. Fingers crossed that the non-recessed original puts him in the ballpark. Maybe this will reinforce what I was trying to tell him about check then cut. He also bought a spark plug from me, because the standard head uses short threads. A BR8EG with a 19mm reach looked about perfect to me when screwed into the head. He said later that it's too long, but I have no idea where that came from suddenly unless he means it's too tall because it's a vertical engine and he'd need a stubby plug. No way the crush washer thinned so much that what looked fine to me is not protruding into the cylinder too much for a guy that doesn't sweat any details.
Post by 90GTVert on May 2, 2024 12:45:27 GMT -5
The old mower wouldn’t even move when cold. After a minute it goes slow and then the smell of rubber burning accompanied more speed. Found a plastic idler pulley in bad shape. New metal replacement and belt ordered. Sharpened blades while I have the deck off anyway. One bolt head stripped. Hammered a 15mm socket onto a 5/8” hex head to get it off and then had to press the bolt out of the socket. Replacement blade bolts on the way too. Might was well mount the spray bar that’s been sitting here for months to the cart while I’m at it. Decided to mount to the cart instead of the mower because the old mower may or may not be around much longer. Waiting on a Y shutoff and hose so I can plumb in the wand and bar and switch to either as needed.
Post by oldgeek on May 2, 2024 18:32:43 GMT -5
I cut a head for a friend. He had a 50mm and a 54mm (actually 53.something). Both with no recess for the squish band/combustion chamber. He wanted one to match an old head with a .8-9.mm recess. I tried to tell him to check first then cut. He said just cut it and he'll check it later, rationalizing that the cylinder and piston look like the same heights as what he had before than needed the recessed head that he brought along so it should be the same with the new stuff. I tried to tell him that's flawed logic. I did at least convince him to leave the 54mm head alone and let me cut the 50mm to 54mm. He didn't realize I could do that. He had sent me a video showing someone cutting a head that was 20-30 seconds long. I've cut heads before on the lathe and using a drill as a lathe with just files to cut before that. I spent a good bit of time trying to at least come close to the angle of the squish band. He told me just cut it straight, it's fine. I cut it to match anyway. After a couple of hours to get it setup and cut, I said there you go... 10 seconds. Looks a lot easier on the internet. Finish isn't perfect, but it's me and a Chinese mini-lathe. The scratch on the original 54mm head is from me trying to check angle by running across it with a tool. I had a dial indicator setup on the tool post and then realized that I can't use it at that angle because the little lathe runs out of range. Setup a dial indicator to go against the carriage to measure how much I was cutting in to make it easier, but then it couldn't fit the space I had either. Came out OK in the end though. I then demonstrated a squish clearance check and gave him a piece of 1.57mm thick solder to use. He messaged me later that it didn't even touch the solder with the head that he wanted cut. I don't know what standard clearance figures are for a 125cc Dio build, but I told him probably 1-1.2mm would be fine just based on 2% of the stroke or so with a little margin for error. Fingers crossed that the non-recessed original puts him in the ballpark. Maybe this will reinforce what I was trying to tell him about check then cut. He also bought a spark plug from me, because the standard head uses short threads. A BR8EG with a 19mm reach looked about perfect to me when screwed into the head. He said later that it's too long, but I have no idea where that came from suddenly unless he means it's too tall because it's a vertical engine and he'd need a stubby plug. No way the crush washer thinned so much that what looked fine to me is not protruding into the cylinder too much for a guy that doesn't sweat any details. 125cc LC dio 2 piece head?
Post by 90GTVert on May 2, 2024 22:00:27 GMT -5
125cc LC dio 2 piece head? Yeah. IIRC he said he got it on AliExpress. Looks like THIS. He has an air cooled cylinder with the studs enclosed around the bore and he's cutting sheet metal to go around a few fins. Much different than what I'm used to. The head and cylinder will be separately cooled. Just plumbed together. Not a lot of cooling around the cylinder, but better than AC I guess.
Post by FrankenMech on May 4, 2024 0:43:52 GMT -5
With a lathe you don't have to wait for some parts like that pulley, you can make one... Any box store or hardware store should have a Y shutoff. I have several sitting in my 'hose junk' boxes. I was looking in one the other day for a washer and I did notice I am getting short on replacement hose washers. I failed to remember that when I was in Homie Depot tonight picking up a few furnace filters. I always fail to remember something. Someday maybe they will sell replacement memory units for brains so I can be a full cyborg. Dogs will bark at me like a Terminator unit. Some dogs already look at me with terror in their eyes and run away. Maybe I just stink bad like a walking dead man zombie thing. Maybe I am just OLD.
Post by 90GTVert on May 4, 2024 2:40:02 GMT -5
With a lathe you don't have to wait for some parts like that pulley, you can make one... Any box store or hardware store should have a Y shutoff. I definitely make some stuff that I could buy, even when it doesn't make sense. HERE'S an example recently where I could have saved myself a ton of time and not ate the coating of a wheel or risked a crash learning all the requirements of the job. The material to make the pulley and a bearing would cost more than the $25 pulley and thanks to the age of amazon it was here yesterday along with the belt, hose, and Y. Not to mention the time and risk of failure. I've got the TMAX apart, the two-stroke in need of a top end and who knows what else, and the mower and spray rig all in the garage needing more time so I have more than enough projects in the garage right now and home repair/paint crap waiting. I live with my parents and neither of them can really do anything requiring much skill or physical ability (don't mean offense but it's true at this point) so I have 2 people coming up with projects for me constantly. Dad fell and broke a shelf trying to catch himself the other day, adding another one. He went to breakfast with friends the next day, picked up wood glue at the hardware store he used to work at, and asked me literally 2 seconds after he sat the glue on the counter if I had fixed the shelf yet then went to lay back down to collect his 12-16 hours of daily rest. I looked at local store sites for hose and the Y. Hose is more expensive and I didn't see Ys local unless I wanted to use garden hose instead of 3/8" barbs.
Post by FrankenMech on May 4, 2024 3:18:56 GMT -5
TGFA, LOL I definitely buy too much at Amazon because it saves so much time traveling to and searching stores for many unobtainium parts, pieces, and stuff, -as you noted. TGFA == Thank God For Amazon. Amazon has changed shopping for everything. I placed 20 orders in the last 3 months and 60 orders last year. I don't even want to see how many $$ I have spent there. I have had to return a few things because of defects but most of the time they were replaced. A few times I ordered the same thing from another vendor. Sometimes items were not as described. Houses are a money pit, -there are always things to fix, modify, or improve. I think I will go back to sleep now that I was rudely awakened at 4AM by the need to pee so I can get my 16+ hours of daily rest.
