Post by floyd2133 on Jun 20, 2016 20:34:38 GMT -5
Post by spaz12 on Jun 20, 2016 20:45:47 GMT -5
First, no fan shrouds... bad news. Bad
Run the hose UP the frame somewhere and it should stop that leaking.
Don't forget the fan shrouds if you want that motor to keep running.
Post by floyd2133 on Jun 20, 2016 20:50:41 GMT -5
I am a rookie . run it up the frame meaning? and what are shrouds?
Post by spaz12 on Jun 20, 2016 20:52:27 GMT -5
Zip tie the hose onto the frame so that it's running up.
Hold on and I'll find you the shrouds...
Post by arkie on Jun 20, 2016 20:57:44 GMT -5
Post by spaz12 on Jun 20, 2016 20:58:22 GMT -5
Post by spaz12 on Jun 20, 2016 21:03:46 GMT -5
Did you put a new main jet in the carburetor? It'll need it. And no, I don't know which one you'll need or where to even start. Others will have to help with that question.
Post by floyd2133 on Jun 20, 2016 21:03:49 GMT -5
did I do it right. how should I test it
Post by spaz12 on Jun 20, 2016 21:05:22 GMT -5
Don't run that motor without those shrouds. Seriously, it would be a very bad day for you.
Post by floyd2133 on Jun 20, 2016 21:05:41 GMT -5
Post by arkie on Jun 20, 2016 21:06:56 GMT -5
Yup that's the idea!
Post by floyd2133 on Jun 20, 2016 21:08:04 GMT -5
is this a shroud
Post by spaz12 on Jun 20, 2016 21:08:42 GMT -5
You also need the fan that goes with the shroud and the very specific screw that hold the fan onto the stator.
Post by floyd2133 on Jun 20, 2016 21:09:58 GMT -5
what is a main jet . they just took it out the box n installed it because the one day put on the day before was bad it's a brand new carb 2 days old national I been riding it since Sunday. it booked out on me n shut down for 3 min but crank back up after kicking n push start
Post by spaz12 on Jun 20, 2016 21:10:07 GMT -5
is this a shroud That's one of three parts to the shroud. Oh, and I now see your fan.
