Post by floyd2133 on Jul 12, 2016 13:30:00 GMT -5
Post by 90GTVert on Jul 12, 2016 14:56:50 GMT -5
That doesn't look like a yellow spark in the video. Looks like a good spark to me. There have been so many threads that I can't keep track of what's what. I'd check spark off and move on to fuel and compression. Has compression been checked at this point? I mean with a compression tester for an actual number in psi? That would be nice to know, especially with things I do remember across threads, like the lack of shrouds.
Post by floyd2133 on Jul 12, 2016 15:01:33 GMT -5
OK I get fuel. I got spark. And it pushes my hand at the spark plug. Good compression. However remote start alarm jus clicks when I try to remote start it. Light lights up when I hit lock unlock but no alarm ringing sound. My scooter turns over but does not start. Can the alarm b the problem. How do I troubleshoot the alarm
Post by floyd2133 on Jul 12, 2016 15:03:40 GMT -5
Post by Deleted on Jul 12, 2016 15:06:07 GMT -5
if you have fuel and spark, I don't think the alarm is blocking anything. Are you sure you have enough compression? Without decent compression, it will never start. If you warped the head by getting too hot, that will cause lost compression. With the spark plug in...do you get a lot of resistance when you move the kick starter lever downward by hand? It should be very hard to do.
Bill
Post by 90GTVert on Jul 12, 2016 15:19:10 GMT -5
The alarm would stop it from making spark usually. I could imagine it being setup right or wrong and preventing the starter from working. Shouldn't change anything else, and those 2 things aren't your trouble. I'd forget the alarm for now and focus on just getting it started. Have you tried the simple tactic of using different throttle positions while trying to start it? Sometimes a little or a lot of throttle will get it fired up.
Post by floyd2133 on Jul 12, 2016 15:26:41 GMT -5
I hold the throttle back all the way but nothing happens I have spark
Post by floyd2133 on Jul 12, 2016 15:27:43 GMT -5
Post by floyd2133 on Jul 12, 2016 15:30:02 GMT -5
I also jus tried different positions still no luck.
Post by floyd2133 on Jul 12, 2016 15:37:01 GMT -5
Throttle position
Post by floyd2133 on Jul 12, 2016 17:35:28 GMT -5
If my scooter has low compression how can I repair
Post by 90GTVert on Jul 12, 2016 18:02:56 GMT -5
You'd have to take the engine apart to some degree to find out exactly why it has low compression. Could be quite a few things.
Post by floyd2133 on Jul 14, 2016 12:09:07 GMT -5
Mechanic is coming today
Post by arkie on Jul 14, 2016 13:58:25 GMT -5
Post by floyd2133 on Jul 14, 2016 14:03:40 GMT -5
Mechanic is here it star5ed with a jump. he rode it and said it wanted to die. it won't start without a jumonth any sugestions
