Moved: the sunny scooter project
Related Topics & Stories
More topics from this board
Shoutbox
tony96778: ]my old mechanic rewired to a different cdi i wana go back with the original and need to rewire the harness
May 14, 2013 7:56:49 GMT -5
tony96778: Mechaniic rewired it to fit different one asnd i wanna rewire the orinal harness
May 14, 2013 7:57:37 GMT -5
creeper: hmmm 90gtvert may be able to track a harness diagram dwn for ya tony send him a pm
May 14, 2013 12:34:55 GMT -5
creeper: awwee but the internet offers a great source of info on engines.....the info is out there sumwhere....you can find it deefa
May 15, 2013 10:54:18 GMT -5
zxo0oxz: you guys think this is a good deal for a set of jets? http://www.partsforscooters.com/114-50-Minarelli-Main-Jet-Kit?sc=34&category=133078&whence=
May 16, 2013 17:16:22 GMT -5
fullcollapse: please help
there's no air sucking in the carb of my dio2. compression in block is ok. please help me pls pls pls
May 17, 2013 2:31:31 GMT -5
90GTVert: You may want to start your own thread fullcollapse and explain with as much detail as you can.
May 17, 2013 18:18:20 GMT -5
90GTVert: You're prob either getting water into the airbox/filter when it rains or getting water into electrical connectors. I'd start checking over kill switch and ignition related connectors first and use dielectric gears on them. Check the plug boot and wire.
May 20, 2013 14:32:16 GMT -5
90GTVert: You'll likely need a larger main jet in the carb and possibly needle and idle mixture adjustments. http://49ccscoot.proboards.com/thread/4212/videos-minarelli-carburetor-setting-adjustment
May 20, 2013 14:33:30 GMT -5
