kdx
Post by kdx on Jun 1, 2017 11:39:10 GMT -5
My zuma with bbk exhaust and carb accelerates really slow when warmed up but sometimes hits hard when it firstt starts have had this problem ever since i put th e bigger carb on. I tried to find vacuum leaks but did not find any. Help?
Post by spaz12 on Jun 1, 2017 16:36:22 GMT -5
Does it bog? Does it sputter? Did you go bigger on the jetting when you installed the bigger carb? How big is the carb? You also have a needle to play around with.
My guess though is that you need larger jets.
kdx
Post by kdx on Jun 1, 2017 19:20:52 GMT -5
Delloroto 19mm i increased main jet size but it seemed like it did nothing no matter what size. Do you think i need a bigger pilot jet?
Post by spaz12 on Jun 1, 2017 19:44:40 GMT -5
Open filter or the oem air box? What jets do you have now? Cylinder and pipe? Once you let us know what you have then we can give you a better guess. We can't give you exact numbers, but we'll get you close.
kdx
Post by kdx on Jun 1, 2017 20:37:44 GMT -5
Pod filter is on dont have stock airbox, 105 mj, leovince zxr pipe
kdx
Post by kdx on Jun 1, 2017 20:38:37 GMT -5
Not sure what bbk was on when i bought it. Guessing a malossi because of the clutch springs
Post by spaz12 on Jun 1, 2017 20:48:13 GMT -5
Does it bog?
Post by spaz12 on Jun 1, 2017 20:48:31 GMT -5
Does it sputter?
Post by benji on Jun 1, 2017 20:49:41 GMT -5
I'm guessing somethings going on with the choke. It runs fine cold, but shitty warmed up? Choke circuit could be stuck open maybe.
Post some pics! I love these bikes. I've got one too!
kdx
Post by kdx on Jun 2, 2017 7:14:00 GMT -5
Oh and i forgot that if i mess with the choke it hits the power band quicker. I guess you would call it bogging when i take off
kdx
Post by kdx on Jun 2, 2017 7:14:18 GMT -5
Pics coming later today If i can figure out how to post pictures on android
Post by benji on Jun 2, 2017 9:02:38 GMT -5
Sounds like a leaking choke circuit. You still have the thumb lever for the choke on that one? I'm guessing sticky cable maybe.
kdx
Post by kdx on Jun 2, 2017 11:33:06 GMT -5
Would i be able to unhook the cable or would that mess somthing up?
Post by spaz12 on Jun 2, 2017 16:35:11 GMT -5
Oh and i forgot that if i mess with the choke it hits the power band quicker. I guess you would call it bogging when i take off That's a fuel enrichment circuit, so if it runs better with the "choke" on then you need a bigger main.
kdx
Post by kdx on Jun 2, 2017 19:47:07 GMT -5
Oh and i forgot that if i mess with the choke it hits the power band quicker. I guess you would call it bogging when i take off That's a fuel enrichment circuit, so if it runs better with the "choke" on then you need a How much bigger of a jet should I get. I thought I shouldn't have to run anything bigger than around a 105
