Baotian
Jan 29, 2018 20:15:23 GMT -5
via mobile
Post by moofus02 on Jan 29, 2018 20:15:23 GMT -5
Its been a while, i got the engine from VlatX , meanwhile i bought fast throttle and im waiting for my exhaust wrap to arrive and im putting it back on. I wanted to ask you guys about the top performances TPR 86cc kit , the full pack with crankshaft and kit is not expensive and it seems to be good , they declare it as hyper racing kit, what do u think will it make 22-25hp at the wheel (with all needed componentes ofc) , its good option and cheaper for me to get. I haven't run it but some here haven and it seems strong. If you go that route make sure to check the crank run out. Some have had problems with that
Baotian
Feb 8, 2018 12:57:49 GMT -5
Post by Delpzie on Feb 8, 2018 12:57:49 GMT -5
Okey guys so i wanted to order this pwk needle set from polini but the problem is that it has these needles (HLJ, HKJ, JJS, JLJ, JJL, JJK, JJN, JJM, JJQ, KLK), and everyone says JJH is the best so what to do now should i get only JJH because i dont want to spend money for this set if its gonna be usless.
Baotian
Feb 8, 2018 13:39:05 GMT -5
via mobile
Post by benji on Feb 8, 2018 13:39:05 GMT -5
Baotian
Feb 8, 2018 14:13:08 GMT -5
Post by Delpzie on Feb 8, 2018 14:13:08 GMT -5
Thats from USA it will cost me way too much .... , whats your opinion do u think i will be able to set up the carb with the polini set ?
Baotian
Feb 8, 2018 20:07:55 GMT -5
Post by Delpzie on Feb 8, 2018 20:07:55 GMT -5
I found BGM Set with these (JJH, JJJ, JJK, JJL, JJM) and i must order Malossi E15 filter cuz they dont have stage6 double layer , then if these dont do the job i will order the polini set.
Baotian
Feb 8, 2018 23:14:10 GMT -5
via mobile
Post by benji on Feb 8, 2018 23:14:10 GMT -5
I think the jjh needle is nice to have but not exactly "necessary" if the polini kit seems like it will work then get it. But I would at least check with jetsrus.com cuz I think the jjh needle is only like $6 (plus shipping I'm sure, but it can't be much to mail a jet needle)
Baotian
Feb 8, 2018 23:21:09 GMT -5
via mobile
Post by benji on Feb 8, 2018 23:21:09 GMT -5
Baotian
Feb 9, 2018 1:16:26 GMT -5
via mobile
Post by AtariGuy on Feb 9, 2018 1:16:26 GMT -5
International shipping even on tiny bits is nearly a mortgage payment...
Baotian
Feb 9, 2018 13:32:58 GMT -5
Post by Delpzie on Feb 9, 2018 13:32:58 GMT -5
Thanks for info guys , but i decided i will get from scooter-center , there is 2 bgm sets so i will have a tons of needles will do the job for sure , carb is ordered 28mm pwk (its the same Stage 6 R/T PWK carb except no brand name on it), idle jets from 35-65 and main 132-160.
Baotian
Feb 13, 2018 18:35:00 GMT -5
Post by Delpzie on Feb 13, 2018 18:35:00 GMT -5
Baotian
Feb 18, 2018 17:25:46 GMT -5
Post by Delpzie on Feb 18, 2018 17:25:46 GMT -5
Well change of plans i sold my s6 sport pro kit , now im thinking between tpr 86cc complete kit with crankshaft or i was thinking 2fast kit and crankshaft motoforce evolution(little crazy idea i know) or i wait more time till i get money and i go all in mhr/polini evolution crank and 2fast kit. What do u think i have seen someone drive motoforce evolution 85mm crank on 2fast kit will it hold ?
Post by vlayco985 on Feb 19, 2018 3:24:41 GMT -5
Well change of plans i sold my s6 sport pro kit , now im thinking between tpr 86cc complete kit with crankshaft or i was thinking 2fast kit and crankshaft motoforce evolution(little crazy idea i know) or i wait more time till i get money and i go all in mhr/polini evolution crank and 2fast kit. What do u think i have seen someone drive motoforce evolution 85mm crank on 2fast kit will it hold ? No Damjan,motoforce crankshaft will not last long on 2fast cilinder,I thought you have malossi rhq crankshaft.... Go for top performance tpr kit. Is it kit with 50mm bore by 44mm stroke?
Baotian
Feb 19, 2018 14:45:06 GMT -5
Post by Delpzie on Feb 19, 2018 14:45:06 GMT -5
Yea there is 86cc and 77cc the italians say the 77cc is little stronger it has little more rpm and 86cc more torque.
Baotian
Mar 22, 2018 13:11:51 GMT -5
Post by Delpzie on Mar 22, 2018 13:11:51 GMT -5
Baotian
Mar 25, 2018 22:35:01 GMT -5
Post by Delpzie on Mar 25, 2018 22:35:01 GMT -5
Here is the new carb, it came with 120 main 48 pilot jet , i bought sets for fine tuning , the needle has JJY mark on it. Still dont know how to port this cylinder if someone can suggest i will be thankfull , i plan to port it kinda like this what do you think?
