Baotian
Jun 6, 2018 20:09:52 GMT -5
Post by Delpzie on Jun 6, 2018 20:09:52 GMT -5
Post by Delpzie on Jun 8, 2018 16:30:46 GMT -5
Baotian
Jun 10, 2018 19:19:03 GMT -5
Post by Delpzie on Jun 10, 2018 19:19:03 GMT -5
So i did the portmap today and here is what it says, 29,7hp @14k rpm, so it will be around 22-23hp on the wheel, its just what i wanted now im just waiting for the belt,it should be here max by friday so first start very soon cant wait to hear this beast, meanwhile i will clean some stuff and wire some switches for the egtmeter,voltmeter and thermometer.
Baotian
Jun 15, 2018 15:30:55 GMT -5
Post by Delpzie on Jun 15, 2018 15:30:55 GMT -5
Baotian
Jun 18, 2018 13:20:00 GMT -5
Post by Delpzie on Jun 18, 2018 13:20:00 GMT -5
Today was finally first start, it started on 3rd kick because i forgot the choke totally....it idled rpms were not constant i guess because there was air left inside, then it settled in i tried it a bit, on 45C temperature i gave it full throttle from stand still after 1sec the sound was crazy kinda scared me a bit , then after that when it got to working temps 60C i tried it again i gave full throttle but it just cant rip main jet is way too big, weather is really bad over here so im waiting to get dry and i will put 10 numbers less main jet and fine tune the carb, will post video when i tune it.
Here is video after idling for about 5min. www.youtube.com/watch?v=F_ZqGiWXqhw
Baotian
Jun 22, 2018 18:46:24 GMT -5
Post by Delpzie on Jun 22, 2018 18:46:24 GMT -5
Today i was tuning the carb i got it working on full throttle with 142 main jet , problem is the rpms idk why they are so low they sit on 12 800 and start raising after 100meters to 13 000, the rollers are 3,5grams pretty light but idk why it doesnt want to catch more rpms, my exhaust is strongest on 13 900 but i cant get it to there, the plug is still kinda rich, i dont know what to do im thinking about going down on main jet, tomorrow i will try ngk9 spark plug cuz that is recommended for my kit now im using ngk10. This is with 148mm full throttle 200meters.Setup right now is 142 main, JJN needle , 42 pilot jet , powerjet unknown.
Baotian
Jun 23, 2018 15:08:12 GMT -5
Post by Delpzie on Jun 23, 2018 15:08:12 GMT -5
Today i did short test ride about 15km with ngk br9es,it holds around 13 000rpm and starts revving really fast, i think these days i will put 3,0gr rollers to see what happens. www.youtube.com/watch?v=NqNrlhhJwiw
Baotian
Jul 3, 2018 17:26:37 GMT -5
Post by Delpzie on Jul 3, 2018 17:26:37 GMT -5
Today i did test with the 120 main jet that came with the carb and it revs only 13,000/100rpm its lean, the spark plug is new and i just cant get a reading like i should i will put back the 140main jet and lighter rollers this time. www.youtube.com/watch?v=0-Z1TA0nCSo
Post by Delpzie on Aug 9, 2018 14:19:43 GMT -5
Post by Delpzie on Aug 30, 2018 15:18:38 GMT -5
Baotian
Aug 30, 2018 17:06:21 GMT -5
Post by aeroxbud on Aug 30, 2018 17:06:21 GMT -5
That's a sweet looking clutch.
Baotian
Aug 31, 2018 0:45:10 GMT -5
via mobile
Post by AtariGuy on Aug 31, 2018 0:45:10 GMT -5
Have you checked your ignition curve from 10k+rpm? Could be why you arent hitting beyond 13k?
Post by Delpzie on Sept 1, 2018 1:36:45 GMT -5
Have you checked your ignition curve from 10k+rpm? Could be why you arent hitting beyond 13k? Its all fine thats not the problem its set 2,2m +- like malossi says, with the lighter rollers should be fine probably today i will put the clutch lighter rollers .... i didnt have time yesterday.
Post by Lucass2T on Sept 1, 2018 4:22:26 GMT -5
Have you checked your ignition curve from 10k+rpm? Could be why you arent hitting beyond 13k? Its all fine thats not the problem its set 2,2m +- like malossi says, with the lighter rollers should be fine probably today i will put the clutch lighter rollers .... i didnt have time yesterday. To how many degrees does 2.2mm refer to? Most of the time the setting supplied by the manufacturer is just a base setting in which any motor at least should be able to fire up. It is never just plug and play and there is always tuning involved...
Post by Delpzie on Sept 1, 2018 7:57:41 GMT -5
I havent measured in degrees but im pretty sure malossi cant be wrong everyone run that its tested cant be wrong but if i dont get the rpms with the rollers then def needs more to be in advance will see later.
