Post by lostforawhile on Nov 17, 2017 16:50:26 GMT -5
You had the gap closer on the bench test which produced .5 volts, than the gap on when the stator is mounted and produced 0 volts? The gap between the pickup and flywheel when mounted is about .3mm probably because it has three jaws interrupting the field instead of one piece of metal per revolution
Post by lostforawhile on Nov 20, 2017 11:01:48 GMT -5
it is the flywheel I'm about to put up a post
