Post by insanitywerks on Dec 8, 2017 20:29:27 GMT -5
How do you measure the threads ?
Post by 90GTVert on Dec 8, 2017 23:35:18 GMT -5
Measure the diameter of the threads at their largest point. That should tell you the thread diameter, 5mm or whatever it is. Then you'd need to measure thread pitch. If you have a pitch gauge, you can try that. Otherwise, measure the distance between 2 thread peaks.
Post by insanitywerks on Dec 14, 2017 15:41:41 GMT -5
Ok the thread diameter is 4.7 and the pitch is 1.2.
Post by 90GTVert on Dec 15, 2017 7:18:40 GMT -5
1.2 thread pitch for a 5mm diameter sounds coarse. Looks real close to the pitch of the 6mm jet that won't work. See if their threads will mesh. If so, you've either got the 0.75 thread pitch like that 6mm jet lists or maybe Mx5x0.8. M5x0.8 is common, so you could get a nut and bolt in that size and see if they fit over the jet and into the carb without play or being over tight turning to help you figure out what it is if you actually find similar pilot jets in both sizes. If you can find a jet like it, you prob won't have both choices so whichever it comes in will likely be what you have. I would guess this is what you're after : www.jetsrus.com/a_jets_by_carburetor_type/jets_keihin_N424-74C_slow_27-xxx.htm
Post by Raizer on Dec 16, 2017 5:34:16 GMT -5
I made the same mistake and got the same PWK etc jets from the same seller. These are the ones you want Keihin N424-74C Pilot/Slow Jet For PZ19 PB16/18 /20(small ATV) Kawasaki KLX110 CVKR-D KSV700 LTF KFX KVF750 DR-Z110 KTM YZF-R6 s.aliexpress.com/ve2IBjAb (from AliExpress Android)
Post by RollingThunder on Dec 17, 2017 19:25:06 GMT -5
I ordered a set from Raizer's link. I think my pilot is a tad too rich so hopefully these are the ticket. I would have liked to get genuine Keihin, but they are expensive and hard to find.
Post by tocoo on Dec 24, 2017 3:04:56 GMT -5
I made the same mistake and got the same PWK etc jets from the same seller. These are the ones you want Keihin N424-74C Pilot/Slow Jet For PZ19 PB16/18 /20(small ATV) Kawasaki KLX110 CVKR-D KSV700 LTF KFX KVF750 DR-Z110 KTM YZF-R6 s.aliexpress.com/ve2IBjAb (from AliExpress Android) That's nice. I will order them if I have the money. Did you choose those by the measurements claimed by the seller ? What key words did you use when you searched for idle jets ? I think I used the method ''search for ''gy6 idle jets'', then I order the results through ''review of 4 stars'' and ''number of orders'', then I look at the cheapest products amongst the first results...
Post by Happypancake! on Dec 24, 2017 8:14:42 GMT -5
JetsRus.com
Post by lilpinny on Dec 24, 2017 8:50:02 GMT -5
Yeah. Like pancakes says jets r us has ‘em all. But be wary, the jet is maybe a couple of dollars but the shipping is a lot. So order a range of what you think you might need and get them at the same time. The type of jets are going to depend on your carb. Some places, like drow sports, have sets for the PWK carb.
Post by lilpinny on Dec 24, 2017 8:53:45 GMT -5
Also don’t forget about your needle size. I’ve found that replacing the stock needle on a Kehein PWK or PWK clone with a JJK sized needle helps a bunch.
Post by lilpinny on Dec 24, 2017 9:07:45 GMT -5
I ordered a set from Raizer's link. I think my pilot is a tad too rich so hopefully these are the ticket. I would have liked to get genuine Keihin, but they are expensive and hard to find. Don’t waste you money on a brand name keihon. A) their expensive, b) their that raw metal color and ugly, c) the PWK design has been around forever and their are lots of good copies. I’ve had good luck with the OKO carbs Here is a pwk slow jet kit link www.drowsports.com/oko-pwk-carburetor-slow-jet-kit-10-pcs-30-52/Is it xmas yet? 😁
Post by RollingThunder on Jan 5, 2018 13:06:13 GMT -5
I got my jets in today from the Chinese supplier and they are too small for my PD19J carb, but look like they would probably work fine for the OP's carb. It's my fault though, I didn't measure the threads before I ordered and just assumed they would work in my carb. Oh well! If anyone needs some of the small style pilot jets PM me!
Post by insanitywerks on May 14, 2018 18:50:51 GMT -5
I have been able to find the pilot jet for my bike and got it back on the road. I found the jet at jet r us. the jet is a keihin jet size 35 (SKU-N424-74C). I would recommend this company for the exceptional service I received when asking if they had the jet.
