chub
Scoot Junior
Post by chub on Jan 8, 2018 21:40:32 GMT -5
I have a tao tao thunder 50 that I recently put a BBK on. Since then I had developed an exhaust leak that I cannot get rid of. Have tried a flat metal gasket, a squish gasket and I can't get it to stop. Someone please help
Post by 90GTVert on Jan 8, 2018 21:48:59 GMT -5
Have you looked over the gaskets coming off of it to see where the carbon is? That could tell you if there's a misalignment. Head and header surfaces flat? I sometimes coat exhaust gaskets with a thin layer of Permatex Ultra Copper as well.
Post by gsx600racer on Jan 8, 2018 21:53:50 GMT -5
Post by lilpinny on Jan 8, 2018 22:01:47 GMT -5
Use a permatex gasket maker. Just make sure you use the right one...
Post by lilpinny on Jan 8, 2018 22:14:33 GMT -5
Have you looked over the gaskets coming off of it to see where the carbon is? That could tell you if there's a misalignment. Head and header surfaces flat? I sometimes coat exhaust gaskets with a thin layer of Permatex Ultra Copper as well. Yeah, if you can see the leak you might just need to file a surface flush or something. If you can’t see it, squirt it with soapy water and that should show you
Post by benji on Jan 8, 2018 22:27:40 GMT -5
Have you tried stacking up two gaskets?
chub
Scoot Junior
Post by chub on Jan 8, 2018 22:31:02 GMT -5
I bought a sheet of fel pro hi temp gasket material and that didn't work either. I also tried ultra copper but I only let it sit for like 15 minutes. Is this where I made a mistake? I heard today that I should wait at least 12 hours before I start it so it could set up properly.
chub
Scoot Junior
Post by chub on Jan 8, 2018 22:34:08 GMT -5
Also the gaskets I got from Amazon was a set of two. I thought it was just two gaskets but one was slightly bigger than the other and wondered if they were supposed to be stacked on top of each other?
Post by lilpinny on Jan 8, 2018 23:02:28 GMT -5
Also the gaskets I got from Amazon was a set of two. I thought it was just two gaskets but one was slightly bigger than the other and wondered if they were supposed to be stacked on top of each other? One was prolly for the intake (smaller) and one for the exhaust port (bigger). It might have been a set
Post by lilpinny on Jan 8, 2018 23:05:10 GMT -5
I’d check to see if your exhaust header isn’t bumping up against the head and not letting it sit flush. I had that problem with an intake on a big bore head. I had to file the intake a little to make it clear. You’d have to, perhaps, shave a sliver off your header. I got a picture of it in my build thread.
chub
Scoot Junior
Post by chub on Jan 8, 2018 23:34:55 GMT -5
Ok I'll check all those things but right now that exhaust has me exhausted so I'll let u know how things go
Post by 90GTVert on Jan 9, 2018 6:30:51 GMT -5
I also tried ultra copper but I only let it sit for like 15 minutes. Is this where I made a mistake? I heard today that I should wait at least 12 hours before I start it so it could set up properly. Gotta give it a little time to cure so it's not so easily displaced.
Post by benji on Jan 9, 2018 10:23:59 GMT -5
After I finish putting a motor together I let it sit overnight to cure.
chub
Scoot Junior
Post by chub on Jan 9, 2018 19:35:35 GMT -5
Yeah after trying to double up the fel pro gasket material to no avail. So I just got done putting the copper seal on and I am gonna let it sit overnight since should be twelve hours or better so I am really hoping that it dies the trick. If not then I guess it's goin to the shop so I can pay them a healthy bill but if they can fix it great.
Post by lilpinny on Jan 9, 2018 22:12:30 GMT -5
Forgive my bad sharpie on paper towel diagram. But look for this: Sometimes the header won’t fit right on an aftermarket head. On the right you can (sort of) see where the flange is too big to fit in the space on the header. So even though you can bolt it on it won’t sit flush and you have a gap (even just a little one) that a gasket won’t fix. If you find it, file down that edge so it’ll fit in there. It could be tiny, doesn’t have to be off by much. This happens on intakes too. You can also coat one surface with ink and see that it completely stamps the other part, but soapy water with the engine running will give you a clue as well.
