Post by 90GTVert on Feb 2, 2018 17:11:31 GMT -5
It looks plenty tall, but those spacers are also isolators. They reduce the heat transfer between the head and intake. Not sure how much practical difference they make.
Post by jeff84 on Feb 2, 2018 20:14:34 GMT -5
I have only ever needed them for clearance issues. I suppose the heat transfer from the head to the intake could be an issue in hot weather. in winter though I would think it would make for harder starting.
when I ported a head on my scooter I took too much out of the exhaust side so velocity was way down, it hurt performance especially at the top end. I made that back with an offset woodruff key which advanced the ignition timing 3*. I still have another unadaulterated stock head that I plan on porting as well, but correcting the mistakes I made.
the difference I noticed after porting was more power overall with a crappier throttle response from a stop. however, it wont hit the upper most available rpm range on flat wind free ground. after I advanced the timing it gets closer but still cant quite hit the rev limiter on a flat. hoping once I installed the new head without a huge exaust port I will be able to keep the port velocity up and get back what I had plus some.
sorry if I am making no sense. I have had a bit to drink tonight
