Post by stancejontland on Feb 21, 2019 21:42:07 GMT -5
i have a mikuni carb. only one that would work. one of these guys sent it to me. been so long i cant remember who but as soon as i threw it on it fired right up!!he sent me a few main jets i think. i can post pics of the sizes i have. no needle jets or whatever they are called. and i may have tuned it a tiny bit to get it running "correctly" or at least enough to make it run and stay running.
Post by stancejontland on Feb 21, 2019 21:43:28 GMT -5
Just like oldgeek said. According to your variator your belt hasn't ever traveled higher than the black belt mark on the face. Your gonna want to measure both with calipers. The distance left on your variator and your belt width. Again like oldgeek said your stock belt numbers are your measurements. Angle, width, and length. If your belts running thin less travel, less opening, less top speed. If it's too thin You'll need to replace the belt. Higher belt travel on the variator, higher gear, higher speed. No calipers try a tape and just convert it as close as you can into millimeters. Open that variator if you can. Check for any type of restriction. Rollers could be flat shaped instead of round. Decreasing variator opening. Also related to lower top speed. Just throwing you some ideas here cvt related for speed. Just jumping on to this thread. If you want to GET belt travel up the variator, put the driveface on lathe and shave down the nipple. i dont have direct access to a lathe.
Post by Happypancake! on Feb 21, 2019 21:45:52 GMT -5
Just jumping on to this thread. If you want to GET belt travel up the variator, put the driveface on lathe and shave down the nipple. i dont have direct access to a lathe. You can do it w/ a dremel also. If you want more top end this is the ticket.
Post by stancejontland on Feb 21, 2019 21:46:54 GMT -5
i do have a dremel.
Post by Happypancake! on Feb 21, 2019 21:49:27 GMT -5
Ok. Just trying to help.
Post by stancejontland on Feb 21, 2019 21:55:33 GMT -5
Whats the nipple? What do i shave off? Im open to all ideas and help!
Post by stancejontland on Feb 21, 2019 21:56:48 GMT -5
Here are the jets i have. I would assume the 71 is in the carb? Ill go through my pms and see who i bought the carb from
Post by stancejontland on Feb 21, 2019 21:58:04 GMT -5
oldgeek it was old geek who i bought the carb from!
Post by Happypancake! on Feb 21, 2019 22:03:08 GMT -5
. Nipple. Shave a little at a time
Post by stancejontland on Feb 21, 2019 22:25:05 GMT -5
Shave whats blacked out? I dont think i could do that lol with out messing it up haha. I have a good amount of bits for it though what did you use.
Post by oldgeek on Feb 21, 2019 22:30:52 GMT -5
oldgeek it was old geek who i bought the carb from! Bought is kinda strong since I gave all that stuff to you. 2 carbs and 2 different shipments of stuff, but glad to help. So are you going to bother with taking the CVT apart? Don't shave anything from the pulley, this is a 2T not a 4T and is a bad idea at this point, you dont even have a nipple anyway. Lol!
Post by Happypancake! on Feb 21, 2019 22:35:27 GMT -5
Shave whats blacked out? I dont think i could do that lol with out messing it up haha. I have a good amount of bits for it though what did you use. No. just the top nipple. You want the variator to close more.
Post by stancejontland on Feb 22, 2019 7:18:38 GMT -5
oldgeek it was so long ago i have no idea haha. maybe i just paid shipping?? haha
Post by niz76 on Feb 23, 2019 10:52:42 GMT -5
In any event unfortunately you'll never wish it fixed. Gotta dig in and try some stuff. Lots of simple and free things you can try instead of just guessing and pondering. Takes about ten minutes to either restrict airflow to carb (richen) or give it more airflow (lean) to see if the situation improves. Sorry not trying to be a di@k but seems kinda silly to keep asking for opinions and help without really trying anything?? Anywho- hope u get it figured out and get your power back.
Post by geoffh on Feb 23, 2019 11:05:28 GMT -5
Me? sorry to keep reading this thread but I,m trapped in the headlamps of stupidity,we would all be better off if stance puts a match to it.
