Post by KSR Moto on Feb 15, 2018 15:26:47 GMT -5
I have a taotao 4 stroke everything stock with only performance exhaust, the problem is that from 3/4 throttle to wot doesnt do anything it wont bog down but it stops to react from 3/4 to wot
Post by james82nd on Feb 15, 2018 15:56:41 GMT -5
without a big bore kit it will do that try a 38 pilot jet with a 90 main jet and get rid of the stock air box the 38 pilot jet will help your starting issues in cold weather m4 size 38 pilot jet and buy a performance airfilter 39mm I have a 2014 fully modified taotoa that will do 60MPH
Post by KSR Moto on Feb 15, 2018 17:11:07 GMT -5
I am currently using stock main jet, i also have sport air filter 38mm but didnt installed it yet
Post by KSR Moto on Feb 15, 2018 17:12:24 GMT -5
I have no problems with cold starts only when hot but it is not that bad
Post by james82nd on Feb 15, 2018 18:17:02 GMT -5
looks like you need a Big bore kit, for what you are looking for
stock bore is 39mm vs 52mm they have now on the market 52mm is the bore of a 125cc but with the stock crankshaft in a 50cc is 41.4mm which yields about 88cc it makes a huge difference
I weigh 215lbs and my 2014 50cc scooter will do 60MPH with the 52mm bore kit and all other things I have modified on it.
that is 60MPH at 8000 rpm...which I am running 8 gram dr pulley sliders, but I will upgrade to 8.25, and if necessary to 8.5grams
Post by james82nd on Feb 15, 2018 18:25:13 GMT -5
without going to 24mm carb and BBK(big bore kit), try the 38 pilot jet with a 20mm or 23 mm carb and a 90 main jet and get rid of the stock air box and put on a 39mm air cone filter
Post by james82nd on Feb 15, 2018 18:27:28 GMT -5
also upgrade your Varitor to a DLH with 1.5 grams more than stock. usually stock is 5 or 6 grams. My stock taotao had 6 grams runn 7 grams with the upgrades and WOT should give you the best with stock bore
I also found out that with a Naraku belt 729-18-30 you will gain 5 more MPH top speed. as long as your taotao has the long case and the 729 belt
Post by KSR Moto on Feb 15, 2018 18:41:02 GMT -5
Thanks a lot, the thing is i already had my other scooter modified to bbk(80cc) it ran great but eventualy in a long run it destroyed the bottom end of the engine, that is why i want to fine tune my stock bore on this scooter, but came acroos this problem when it stops accelerating from 3/4 throttle to wot, i will try bigger jet and then put cone filter
Post by kagetenshi on Feb 19, 2018 10:39:23 GMT -5
Might I suggest lowering the clip on the needle in your carburetor. That will allow more air/fuel to flow at wot. If your needle isn't adjustable you can use very small washers that are about 1mm thick to get the same effect.
Post by KSR Moto on Feb 19, 2018 15:17:20 GMT -5
It is already almost at the lowest setting even if I put it all the way down doesnt that mean that something else is off, or am I wrong?
Post by KSR Moto on Feb 19, 2018 15:23:53 GMT -5
Update: Now i have both performance air cone filter and performance exhaust, main jet is now 80, still same issue from 3/4 to wot
Post by scooterpimp on Feb 19, 2018 20:29:13 GMT -5
Usually the 3/4 & up area is main just related.unless your cdi /ignition wont allow advaning past that area (possible ignition issue?) Just tossing ideas out there. Did this issue develop after exaust was replaced?
Post by KSR Moto on Feb 20, 2018 13:34:21 GMT -5
Issue was still present with stock exhaust, but with performance exhaust it reduced top speed from 70km/h to 60km/h Eventually bigger jet solved the problem now it goes 82km/h 😀
Post by dexameth on Mar 2, 2018 14:36:35 GMT -5
Post by GrumpyUnk on Mar 4, 2018 1:21:48 GMT -5
82kph sounds fixed... If not, check that the 'slide', vacuum operated, can move freely and is not stuck. They sometimes get deposits on the needle or emulsifier and stick a bit. It would take some time to get pulled open if sticky. Adding a washer or moving the E-clip to a lower slot on the needle would move the 'base' point of the needle up, thus opening the fuel flow area a bit more. Lowering the needle by removing a washer or moving the E-clip down to a lower slot would make the needle's thicker portion fill the jet square area more, and thus decrease fuel flow. tom
