Post by dexameth on Jun 5, 2018 14:50:18 GMT -5
So wait, you said in the video that when you took it apart that one of the tappets was loose, right?
There's your answer. As that thing is slamming into the valve to lift it the tappet is tapping back and forth in the play of the threads. get yourself a 9mm for that little nut, and some pliers to hold the tappet and LOCK that nut down.
Post by bumtrain on Jun 5, 2018 15:12:30 GMT -5
So wait, you said in the video that when you took it apart that one of the tappets was loose, right? There's your answer. As that thing is slamming into the valve to lift it the tappet is tapping back and forth in the play of the threads. get yourself a 9mm for that little nut, and some pliers to hold the tappet and LOCK that nut down. That is exactly what I did haha. I don't understand how it got so loose though. I tightened it down with a good amount of force when I adjusted the valves the 2nd time.
