Post by geoffh on Dec 8, 2018 10:13:01 GMT -5
Your getting there,what speeds are you getting (mph)fit a new plug and then show us picture taken without flash,the mixture screw only affects idle speed,some pictures of the air box will help,you will need to do a CVT inspection next order a variator locking tool and have you got/lend/ a torque wrench?
cabrinha
Post by cabrinha on Dec 8, 2018 10:24:11 GMT -5
Your getting there,what speeds are you getting (mph)fit a new plug and then show us picture taken without flash,the mixture screw only affects idle speed,some pictures of the air box will help,you will need to do a CVT inspection next order a variator locking tool and have you got/lend/ a torque wrench? Geoff 69kmh. Stock airbox with clean filter. www.pedparts.co.uk/product/2109/17mm-gurtner-style-carb-choke-jog-aeroxThis is the carb that I have installed.
Post by geoffh on Dec 9, 2018 15:08:45 GMT -5
OK 69kph is good enough for a stock motor,change the plug!! Don't,t dodge around the air box question you might be running lean and that will lead to failure.your doing well for a newbie.
