Post by lilpinny on Jan 23, 2019 15:39:15 GMT -5
Someone back on TR used to shave off the fins for some dough. Forget who that was.
Post by fugaziiv on Jan 23, 2019 16:02:29 GMT -5
Someone back on TR used to shave off the fins for some dough. Forget who that was. Not sure I'd recommend that since they kind of are meant to keep the face temp down, but I mean, yeah that's one way to deal with them I guess. Matt
Post by lilpinny on Jan 23, 2019 16:09:03 GMT -5
Someone back on TR used to shave off the fins for some dough. Forget who that was. Not sure I'd recommend that since they kind of are meant to keep the face temp down, but I mean, yeah that's one way to deal with them I guess. Matt Maybe PC the exposed side.
Post by fugaziiv on Jan 23, 2019 16:27:29 GMT -5
Not sure I'd recommend that since they kind of are meant to keep the face temp down, but I mean, yeah that's one way to deal with them I guess. Matt Maybe PC the exposed side. PC?
Post by lilpinny on Jan 23, 2019 16:39:55 GMT -5
Maybe PC the exposed side. PC? Powder coat. That raw color has to go!
Post by fugaziiv on Jan 23, 2019 16:47:48 GMT -5
Powder coat. That raw color has to go! Ahhh, I see! Thanks for the clarification. I'd leave it raw, or maybe anodized. Powder coating would insulate the aluminum and I think you'd lose some of the effectiveness of the heat sink. Matt
Post by fuzzyruttin on Jan 23, 2019 17:44:36 GMT -5
Couple more questions to wrap up a decision: - The drive face is not included in the Polini link that you provided (though it does come with a new clutch spring). Does that mean stock drive face is fine, or is there a drive face that couples better with the Polini? - DR variator is built to use DR sliders, that's a no-brainer. Would you suggest running DR sliders with the Polini, or regular rollers?
Post by lilpinny on Jan 23, 2019 20:42:15 GMT -5
Couple more questions to wrap up a decision: - The drive face is not included in the Polini link that you provided (though it does come with a new clutch spring). Does that mean stock drive face is fine, or is there a drive face that couples better with the Polini? - DR variator is built to use DR sliders, that's a no-brainer. Would you suggest running DR sliders with the Polini, or regular rollers? You can run sliders in anything. Sliders work much better than rollers, imho.
Post by lilpinny on Jan 23, 2019 20:44:05 GMT -5
Powder coat. That raw color has to go! Ahhh, I see! Thanks for the clarification. I'd leave it raw, or maybe anodized. Powder coating would insulate the aluminum and I think you'd lose some of the effectiveness of the heat sink. Matt I'm going to try it, if I like it I'll figure out how to pretty it up.
Post by fugaziiv on Jan 24, 2019 9:18:32 GMT -5
Couple more questions to wrap up a decision: - The drive face is not included in the Polini link that you provided (though it does come with a new clutch spring). Does that mean stock drive face is fine, or is there a drive face that couples better with the Polini? - DR variator is built to use DR sliders, that's a no-brainer. Would you suggest running DR sliders with the Polini, or regular rollers? Stock drive face plate is fine with the Polini. Most variator improvements happen on the back side of the variator itself. The drive face angle of the Polini variator matches up to the stock drive face plate. The Dr. Pulley one is ever so slightly different. You can totally run sliding weights in any variator, and many of us do. I highly recommend them for almost any application. Matt
Post by fugaziiv on Jan 24, 2019 9:19:08 GMT -5
Ahhh, I see! Thanks for the clarification. I'd leave it raw, or maybe anodized. Powder coating would insulate the aluminum and I think you'd lose some of the effectiveness of the heat sink. Matt I'm going to try it, if I like it I'll figure out how to pretty it up. I'm very interested to see how this works out. Keep me posted. Matt
Post by fuzzyruttin on Feb 2, 2019 21:16:46 GMT -5
Couple more questions to wrap up a decision: - The drive face is not included in the Polini link that you provided (though it does come with a new clutch spring). Does that mean stock drive face is fine, or is there a drive face that couples better with the Polini? - DR variator is built to use DR sliders, that's a no-brainer. Would you suggest running DR sliders with the Polini, or regular rollers? Stock drive face plate is fine with the Polini. Most variator improvements happen on the back side of the variator itself. The drive face angle of the Polini variator matches up to the stock drive face plate. The Dr. Pulley one is ever so slightly different. You can totally run sliding weights in any variator, and many of us do. I highly recommend them for almost any application. Matt fugaziiv, I got the Polini variator installed today, and forgot to measure the roller size. Are they 19x17s? I'm not 100% sure after searching the web. The stock GY6 is 18x14, so I certainly can't use my new set of sliders, which are probably way to heavy anyway. The new Polinis are 9.7g, I had 14g on the old variator. Also, what are the chances I'll need a shorter belt? Currently got a 842-20-30 installed. It's supposed to get near 40F tomorrow. With any luck, the rain will hold off long enough for me to do some tuning.
Post by Happypancake! on Feb 3, 2019 21:31:04 GMT -5
Agreed. For the Honda GET Polini w/ sliders is the way to go
Post by fugaziiv on Feb 4, 2019 9:49:56 GMT -5
Stock drive face plate is fine with the Polini. Most variator improvements happen on the back side of the variator itself. The drive face angle of the Polini variator matches up to the stock drive face plate. The Dr. Pulley one is ever so slightly different. You can totally run sliding weights in any variator, and many of us do. I highly recommend them for almost any application. Matt fugaziiv, I got the Polini variator installed today, and forgot to measure the roller size. Are they 19x17s? I'm not 100% sure after searching the web. The stock GY6 is 18x14, so I certainly can't use my new set of sliders, which are probably way to heavy anyway. The new Polinis are 9.7g, I had 14g on the old variator. Also, what are the chances I'll need a shorter belt? Currently got a 842-20-30 installed. It's supposed to get near 40F tomorrow. With any luck, the rain will hold off long enough for me to do some tuning. The Polini does use 19x17 weights, that's the size Polini has determined to be ideal. I agree that 14 sounds a bit heavy. I'd install the stock weights, and then start tuning from there. If you're happy with the variator and the provided weights, then you're good to go for a bit. As far as belts, did your engine come stock with the 842, or was that installed after? Normally a long case GY6 runs the 835, and unless your engine calls for the longer belt I'd recommend the shorter. Matt
Post by fuzzyruttin on Feb 4, 2019 19:20:55 GMT -5
Agreed. For the Honda GET Polini w/ sliders is the way to go Well, this is a GY6 Ruck, but I GET the idea
