Post by snaker on Apr 18, 2019 8:47:14 GMT -5
Your diagnostics point to the CVT. You should be able to confirm if its engine or CVT.
Is the engine bogging down and running poorly? Problem is engine. Is the engine rpm revving to the moon? Problem is belt or clutch slippage. Is it acting like it stays in high gear (one of your symptoms listed)? Problem is CVT binding
Don't mess with the engine until you confirm the CVT is good.
Post by insanesmc on Apr 20, 2019 13:51:44 GMT -5
Your diagnostics point to the CVT. You should be able to confirm if its engine or CVT. Is the engine bogging down and running poorly? Problem is engine. Is the engine rpm revving to the moon? Problem is belt or clutch slippage. Is it acting like it stays in high gear (one of your symptoms listed)? Problem is CVT binding Don't mess with the engine until you confirm the CVT is good. pretty sure its the CVT, engine is running fine and i rebuilded it like 1000km ago so there should not be any problem and plenty of Power when it works, it feels like the clutch or belt is giving me the problem ill try to get a replacement belt when i have the money and the problem is that if i slow down it doesnt respond to throttle and wont accelerate but if i stop completely or lock my rear brake its fine and there might be little bit of Power loss when the cvt gets hot. Im just completely Lost and unmotivated to fix this problem.
Rune 75
Post by Rune 75 on Apr 20, 2019 14:09:47 GMT -5
Tried std contra and weights yet ?
Post by insanesmc on Apr 20, 2019 15:37:30 GMT -5
Tried std contra and weights yet ? yeah 8.5g and stock contra it was worse and it wasn't that long of a ride i might try them with the 139qmb spring and 7,5g next, one thing i noticed that the pins in the rear pulley scored the part that goes on top of them where the spring sits dont know if it cause this issue
Rune 75
Post by Rune 75 on Apr 20, 2019 16:21:02 GMT -5
Tried std contra and weights yet ? yeah 8.5g and stock contra it was worse and it wasn't that long of a ride i might try them with the 139qmb spring and 7,5g next, one thing i noticed that the pins in the rear pulley scored the part that goes on top of them where the spring sits dont know if it cause this issue Yes that will definitely cause the problem. The rear pulley will stick an shift poorly.
Rune 75
Post by Rune 75 on Apr 20, 2019 16:27:53 GMT -5
These grooves need to bee absolutely flawless/smooth.
Post by insanesmc on Apr 21, 2019 4:41:31 GMT -5
These grooves need to bee absolutely flawless/smooth. They are but the part that goes over that there is some scoring
Rune 75
Post by Rune 75 on Apr 21, 2019 5:08:26 GMT -5
Ok. You mean the cap that goes on the outside. The pins will probably put som marks inside the cap but shouldn't score it. The pins shouldn't reach that cap when they're in place but they will get thrown out against the cap when the pully turns at high speed. That cap should glide on very easily.
Post by insanesmc on Apr 21, 2019 8:41:52 GMT -5
Ok. You mean the cap that goes on the outside. The pins will probably put som marks inside the cap but shouldn't score it. The pins shouldn't reach that cap when they're in place but they will get thrown out against the cap when the pully turns at high speed. That cap should glide on very easily. Yeah ill put a picture of it later, i tried it with the 8.5g setup and 139qmb spring and it got worse
Post by insanesmc on Apr 21, 2019 13:51:48 GMT -5
The blue spring is the 139qmb spring and the black one is stock.
Rune 75
Post by Rune 75 on Apr 21, 2019 16:01:30 GMT -5
Cant really se how those marks would cause any problems.
Dont get fouled by the length of the springs, it's how much force needed to compress them fully that mathers.
Post by insanesmc on Apr 23, 2019 0:28:38 GMT -5
Cant really se how those marks would cause any problems. Dont get fouled by the length of the springs, it's how much force needed to compress them fully that mathers. Okay, maybe its the belt i measured the width of it and its supposed to be 18mm and its about 17mm
Rune 75
Post by Rune 75 on Apr 23, 2019 2:55:40 GMT -5
Cant really se how those marks would cause any problems. Dont get fouled by the length of the springs, it's how much force needed to compress them fully that mathers. Okay, maybe its the belt i measured the width of it and its supposed to be 18mm and its about 17mm Belts wear down, it's normal. They are usually changed when they are worn 1,5mm from new. When the the belt looses width the top speed drops. You usually loose about 3mph pr mm wear on the belt. I can't see this causing your problem either.
Post by insanesmc on Apr 25, 2019 6:53:25 GMT -5
Ive decided that i buy a new contra spring, belt and clutch springs so i can eliminate many problems as possible
Rune 75
Post by Rune 75 on Apr 25, 2019 7:25:07 GMT -5
If that doesn't solve the problem you should consider a new torquedrive.
