Post by GrumpyUnk on May 5, 2019 16:57:37 GMT -5
I would try another carburetor. When they won't start as described, I think there is a blockage of some sort, and I have not found out where it is. I have 4 carbs awaiting me looking more closely at them for faults. I had problems getting started, it would start and run for 10-15 seconds, and die, and die immediately if I opened the throttle at all. Swapped carbs, did nothing else, and off it goes. No problem. I tried all sorts of adjustments, to no avail. Still don't know what it is.
The book I have states valve clearance as follows:
Intake .03.05mm == .001-.0015in Exaust .05-.07mm == .002-.0027in
So by that book, your clearances are too large at .004", being about double. tom
Post by johnwohl on May 5, 2019 23:16:19 GMT -5
OK, I'll readjust the valves and give it a go and if that doesn't work I'll try a new carb. I would like to get this one working though as the "real 20mm carb" wasn't as cheap.
