Post by magoconnor on Apr 27, 2019 16:22:49 GMT -5
Post by magoconnor on Apr 27, 2019 17:19:24 GMT -5
Post by magoconnor on Apr 27, 2019 23:46:21 GMT -5
Here are some more pictures of the eight pole stator's lose wire, I dont really think it does anything, its only connected to the red wire for the cdi. But maybe you can see better on the new picture, if it's of any importence. The six pole stator: There is 0.8 ohms between the ground wire and the white wire. But its the same on the eight pole stator, only that it does not have a ground wire leaving the stator.
Rune 75
Post by Rune 75 on Apr 28, 2019 3:58:22 GMT -5
The wires spun around the coils is suppose to be (must be) one long continuous wire. If it is broken the coil won't work. The wire sticking out of the plastered coil is the same thin wire that is used on those plastered coils. The wire sticking out could be a leftover from production. It's hard to tell from a picture. If the coil is broken you will measure indefinitely ohm on that coil. As someone mentioned earlier, try it on. If it works it works, if not it's broken. The wire sticking out, as long as it is one single wire, can just be snipped off. Makes no difference.
Post by magoconnor on Apr 28, 2019 9:38:53 GMT -5
Okay is there a way I can measure if its trash?
Rune 75
Post by Rune 75 on Apr 28, 2019 9:46:59 GMT -5
Post by magoconnor on Apr 28, 2019 10:41:47 GMT -5
I think its good, so Im just gonna go ahead and trim it and give it some glue.
Rune 75
Post by Rune 75 on Apr 28, 2019 11:12:11 GMT -5
Why did you remove that stator in the first place ? Or is it a second hand stator you haven't tested ?
Post by magoconnor on Apr 28, 2019 18:49:59 GMT -5
I blew a crank seal, but until then it worked great.
Rune 75
Post by Rune 75 on Apr 29, 2019 2:31:11 GMT -5
I blew a crank seal, but until then it worked great. I see. That wire must have been sticking out since the scooter left the factory then, probably.
