pewpew
Post by pewpew on Feb 25, 2021 17:01:22 GMT -5
are you reffering to the easy boost sub frame for rear faced carb? im asking because i was gunna get one for myself but i was wondering if you had to bore out another mounting hole on the frame itself because thats what it shows . did you have to do this and did you drill a hole on the ear of the engine swing arm ? Yes, I havent mounted it yet but what hole do you mean?
Post by xtremrox on Mar 5, 2021 15:12:33 GMT -5
are you reffering to the easy boost sub frame for rear faced carb? im asking because i was gunna get one for myself but i was wondering if you had to bore out another mounting hole on the frame itself because thats what it shows . did you have to do this and did you drill a hole on the ear of the engine swing arm ? There is a bit of a scam whit easyboost i ordered the easyboost subframe whit the desing that need new holes on the frame but recives the one whit the desing that you need to cut the crankcase a bit. Then i looked in to things and what i found was stunning easyboost dosent even make the desing that is sold on maxiscoot for example
pewpew
Post by pewpew on Mar 31, 2021 8:54:28 GMT -5
Post by Lucass2T on Mar 31, 2021 9:48:48 GMT -5
Very nice! I like the color on the wheels!
Post by aeroxbud on Mar 31, 2021 17:09:48 GMT -5
It's came out really nice. The purple colour should really pop in the sun.
pewpew
Post by pewpew on Apr 9, 2021 18:18:21 GMT -5
Post by hippo008 on Apr 10, 2021 15:53:35 GMT -5
Nice job on the engine polish. That's not easy to do.
Post by aeroxbud on Apr 10, 2021 16:56:23 GMT -5
That's a big intake! Loads of power. 😁
winner3ty
2 Strokes for life
Post by winner3ty on Apr 10, 2021 21:02:37 GMT -5
Dang sweet progress
pewpew
Post by pewpew on Apr 16, 2021 17:48:33 GMT -5
pewpew
Post by pewpew on Apr 28, 2021 14:03:45 GMT -5
Has anyone had a tachometer on the mvt dd ignition? I had it connected to the blue and white wire on mvt millenium ignition but these dont that and coil + wire doesnt work
Post by 90GTVert on Apr 28, 2021 15:24:23 GMT -5
I've been using a Trail Tech Vapor tapped into coil + with a DD06 without issue for quite a while. Not sure about your gauge, but with the Trail Tech you can also try wrapping the tach wire around the plug wire (usually 3-5X). Normally scoots need 1 pulse per revolution, but I have to set it to 2 PPR for the DD06.
pewpew
Post by pewpew on Apr 29, 2021 9:09:46 GMT -5
I've been using a Trail Tech Vapor tapped into coil + with a DD06 without issue for quite a while. Not sure about your gauge, but with the Trail Tech you can also try wrapping the tach wire around the plug wire (usually 3-5X). Normally scoots need 1 pulse per revolution, but I have to set it to 2 PPR for the DD06. I have the koso db-02r gauge, it came with a wire with a black and white wires, black is ground and white has 2 connectors, 1 goes to the coil + wire and one goes to the coil + pin, i tried it but the rpm showed 0 when i started it
Post by 90GTVert on Apr 29, 2021 11:34:29 GMT -5
I looked up instructions and it says you can wrap the B type of RPM wire set around the plug wire, and connect both wires to each other. So connect the male and female plugs that are for coil +.
It also says to be sure you use a resistor plug.
Beyond that, you may have to get it touch with either Koso or MVT. Maybe try it on any other setup if possible. You could just pull another bike beside it and wrap around it's plug wire or do the inline coil + connection and see if that registers.
pewpew
Post by pewpew on May 5, 2021 13:25:09 GMT -5
Just placed an order for some tools, a new handlebar, Stage6 4 piston caliper and adapter. I already have the Stage6 280mm disc so they should work well together. This is how the bike looks now, still need to mount the rear plastics and front brake. I crashed the bike during a police chase and the pipe got a huge dent luckily got away tho.
