Post by milly on Feb 26, 2022 10:49:38 GMT -5
Post by milly on Mar 7, 2022 12:36:56 GMT -5
Plastic welding today is as good as my metal welding but less painful 😊
Post by milly on Mar 8, 2022 12:11:27 GMT -5
Gaiters on and found a spare Vespa master cylinder in spares box to replace the seized one. Glad i checked threads on banjo bolt as both different but we now have a working front disc.
Post by milly on May 2, 2022 12:18:03 GMT -5
Time to tinker in the shed for a change. Changed master cylinder for a new one i found and carb changed and got engine running smoothly. Battery tray put back and floor. Hunt out new indicator switch next.
Post by milly on May 3, 2022 14:42:10 GMT -5
Post by milly on May 14, 2022 13:38:32 GMT -5
New light switch on now I have main beam/dip.
Post by milly on May 18, 2022 3:33:00 GMT -5
New rear light fitted and working. Next today is Speedo wiring and tidy a few bits up. Soon be time look for another project.
Post by milly on May 19, 2022 15:37:43 GMT -5
Mostly back together now with the aid of a bit of wood filler and random nuts and bolts and screws. Everything works just need to cable tie some electric wiring out the way and bolt down the seat bucket. Best check oil can't remember if I changed it most likely not and a registration plate tomorrow. Actually looks tidier in pics than real life. But it is a Rat scoot. Don't need anything to impress the girls at my age.😃 Was going to put some custom bits on but to much faffing about will sell those on fleabay.
Post by milly on May 21, 2022 14:31:57 GMT -5
Just road tested the Rat, changed oil runs ok but carb may want cleaning we'll see. Just make a battery cover and off for the mot. Looks much better parked by greenery hides a lot of it 😃
Post by milly on May 24, 2022 10:11:01 GMT -5
Off for the mot. Battery cover now fitted 😃
Post by milly on May 24, 2022 11:55:05 GMT -5
And it passed.
Post by aeroxbud on May 24, 2022 15:01:36 GMT -5
That's good. That number plate looks huge on there.
br4inl3ss
Post by br4inl3ss on May 24, 2022 18:33:40 GMT -5
And it passed. hey amazing work out there buddy ! did you mean it passed inspection ?
Post by repherence2 on May 24, 2022 21:49:30 GMT -5
when i saw the number plate, i sarcastically thought, Billboard... like mount it on a pole and put up high like a bicycle flag. but after thinking about it, it is probably that big due to Safety, especially of the plate is reflective.
Post by aeroxbud on May 25, 2022 2:48:04 GMT -5
That's good. That number plate looks huge on there. when i saw the number plate, i sarcastically thought, Billboard... like mount it on a pole and put up high like a bicycle flag. but after thinking about it, it is probably that big due to Safety, especially of the plate is reflective.
It's the law. They have to be a certain size. Without the correct size plate it won't pass the yearly vehicle inspection. We have the largest licence plates in Europe. 😞
