sinfull
Post by sinfull on Mar 11, 2023 23:49:26 GMT -5
Definitely keep it going, I would strip it down and get rid of the rust and repaint frame, you have gone this far with it you may as well go all the way
Post by milly on Mar 12, 2023 7:06:55 GMT -5
Yes I think a full strip down and hammerite or some such thing on the frame is worthwhile doing. So long term project here and overtime may find a decent front panel cheap and not silly money.
Post by milly on Mar 12, 2023 14:05:21 GMT -5
Today I managed to attach the new oil feed pipe from carb to pump after moving the heat shield then removed Speedo casing screws to get at throttle and release it so I could disengage the old cable ready to replace it. Spent the next half hour wondering where I put the new cable in a tiny shed but found it was exhausted by then and went to bed for a hour or two, to wake up thinking bungalow is hot but been informed it's me and not the bungalow. Hopefully ok for work in the morning.
Post by milly on Mar 13, 2023 13:12:13 GMT -5
Done a bit more today but not a lot was sweating profusely after running the new throttle cable through. A faff and a half to run that through.
Post by jackrides on Mar 13, 2023 16:01:24 GMT -5
Sounds like you need a personal health day Milly. Take care of yourself!
Post by milly on Mar 13, 2023 17:02:04 GMT -5
Sounds like you need a personal health day Milly. Take care of yourself! Thank you I did take today off work but find it hard doing nowt only working tomorrow in the morning for a couple of hours and then home to bed.
Post by milly on Mar 21, 2023 13:42:28 GMT -5
This afternoon I got the front wheel in and the engine this afternoon with the help of the neighbours daughter and then we got the Vespa ET4 project in but got caught out bringing in engine in by Yolanda.
Post by FrankenMech on Mar 21, 2023 15:43:59 GMT -5
One of the tools I use in the shop for manhandling heavy parts is a hand winch secured above to a 4x4 laying across several ceiling joists and a bit if chain and lots of bolts and washers. I have a couple setups in the garage and 3 more in the carport. It makes dismantling and assembling easier. Hand winches are not supposed to be used for overhead lifting so I make sure I don't get any body parts under things. I have never had one fail yet. I do buy good brand name high quality units, not cheap ones. I also use a good quality chain hoist. They must be used with care though. I supplement them with jack-stands, wood timber cribbing and lots of chain and fittings. Never use cinder blocks, they crack and shatter. I also have jacks, engine hoists, and other lifts. Nothing as nice as your auto shop lifts.
Post by milly on Apr 6, 2023 13:20:50 GMT -5
Today I moved it back to the garage so I can do it with the use of the ramp.
Post by FrankenMech on Apr 6, 2023 17:39:58 GMT -5
A nice raised platform work bench area. You are a lucky man
Post by milly on Apr 8, 2023 14:40:48 GMT -5
Today I had chance to put on the exhaust and a exhaust syud in the cylinder and connect up the oil pump cable and lines.
Post by aeroxbud on Apr 8, 2023 15:12:50 GMT -5
The exhaust fastening look factory spec. New old stock?
Post by milly on Apr 8, 2023 15:22:56 GMT -5
The exhaust fastening look factory spec. New old stock? Second hand off eBay. Can these be tuned up much not checked YouTube yet but the Sj 100 has very little on tuning them but I'm happy with that stock.
Post by aeroxbud on Apr 8, 2023 16:42:45 GMT -5
Post by milly on Apr 9, 2023 5:56:56 GMT -5
Thank you aeroxbud, just check out a 17mm carb for it. They have some on racing planet I shall look later.
