Post by 90GTVert on May 28, 2023 8:50:57 GMT -5
Glad to see you're making sure it's ready to rack up some miles.
Now you can do a race setup in the scoot since you've got this capable machine as a reliable ride. 🎉 Time to party! 🎈 Everybody get your wheels in the air and ride 'em like you just don't care. 😁
Post by captincvmn on May 28, 2023 8:55:34 GMT -5
The Guzzi forums strictly adhere to the 10/60. Dry clutch so no special friction stuff required.
Post by 190mech on May 28, 2023 17:00:19 GMT -5
10-60 is stupid,WHY? A Guzzi is a pretty layed back motor unless I'm missing something..Am guessing it's a plain bearing crank with a separate tranny..Any explanation as to why you need this rocket oil?? Would think Mobil 1 15w-50 would FAR surpass the 10-60 stuff.. Bob is the oil guy site has all the folk that eat and drink lubrication tech bobistheoilguy.com/forums/
Post by captincvmn on May 28, 2023 17:17:03 GMT -5
I have no idea. Flat tappet air cooled with oil cooler. Shrug? Doesn’t matter. I’ll spend the $60/6,000 miles to oil the bearings. The experienced Guzzi guys said to not deviate.
lagrasta50cc
Post by lagrasta50cc on May 30, 2023 10:47:13 GMT -5
Congrats on the Guzzi, I own a 2003 V11 and a 2010 V7; amazing bikes. Both are super dependable, the V7 now has over 23k, never any issues (just valve adjust and fluids chenges). As for the light coming on at 2k. This does happen to me from time to time as well. It has something to do with case pressure. I've addressed it, but to no avail. With that said, it's never caused a single problem.
As for oil, I live in SoCal so fluctuating weather temps is a non issue, I run 20w50, cheap and easy to find.
Post by captincvmn on May 30, 2023 18:56:03 GMT -5
She passed her Pennsylvania state inspection today. Legal to run.
Post by aeroxbud on May 31, 2023 3:27:58 GMT -5
No stopping you now. Got any trips planned?
Post by captincvmn on May 31, 2023 5:09:28 GMT -5
No stopping you now. Got any trips planned? Maybe some special tags today. Doesn’t seem fair though as my tag gathering range is very wide now compared to my 10mi radius of the house prior to this.
Post by aeroxbud on May 31, 2023 14:48:10 GMT -5
No stopping you now. Got any trips planned? Maybe some special tags today. Doesn’t seem fair though as my tag gathering range is very wide now compared to my 10mi radius of the house prior to this. I had a look for the nearest water tower. It's 44 miles away, longer not using a freeway. That's a mission on a 50cc. 😂
Post by captincvmn on May 31, 2023 18:28:26 GMT -5
Yeah that’s too far. I passed numerous ragtops today but can’t take pics while I’m moving.
Post by captincvmn on May 31, 2023 18:29:23 GMT -5
This was my route this morning.
Post by captincvmn on Jun 13, 2023 21:55:44 GMT -5
Post by captincvmn on Jul 1, 2023 9:01:34 GMT -5
I did change the oil pressure sensor, made the oil light problem go away. Now I have a few random oil leaks to chase down. Oil leaks are never a good thing. I adjusted the valves and that quieted things down a lot. PO said the valves had just been done but that’s BS, I could have driven a truck through the valve gap on one of them. Overall it wasn’t hard to do. .0015 exhaust and .0010 intake. Measure/adjust/rotate/measure/adjust/rotate over and over until it’s stable. Took typically four adjustments to make for good. Sounds better now.
Post by aeroxbud on Jul 1, 2023 12:08:28 GMT -5
Is that still the old GY6 style adjustment rather than the bucket and shim type I guess? It doesn't stay in specification as long. But easier to do. The amount of motorcycles I have brought and the dealer was supposed to have done a full service on. But didn't is quite a few. Always best to do it yourself Rob.
Post by captincvmn on Jul 1, 2023 19:05:57 GMT -5
I’ve never seen bucket and shim or GY6 These have an adjuster bolt on the rocker arm with a lock nut.
