Post by Scootrific on Jan 16, 2024 16:49:32 GMT -5
Post by Scootrific on Jan 17, 2024 15:58:31 GMT -5
The Aixam Hertz Sound System will be like this, what I´m planing to do with the car: ----------------------------------------------------------------------------------------------- Head unit: Pioneer MYH-S32BT (I might swap it out to a Pioneer DMH-G221BT multimedia unit) Front Speakers Hertz DPV 165.3 (inside doors): Back Speakers (inside a box): Hertz Dieci DCX 690.3 Amplifier (4 channel): Hertz Compact-Power HCP 4 Amplified subwoofer: Hertz DBA 201 F kit Noise damping: STP Black Silver, LAVA, Accent 6, Accent 10, Biplast 25 WAVE Cabel-kit: Auto-Connect PK-CCA 35mm² (amplifier up to 1300W) Today came in the Car Parking Sensor kit with 4 sensors, for the Aixam. I´m gonna install it to the rear of the car. New moped-Cars have this accessory, why should my 2015 Aixam City not have one? Im planing to kit out the Aixam, with almost the same spec as the Casalini M20 550 Trofeo.
Post by Scootrific on Jan 20, 2024 3:55:56 GMT -5
Yesterday came in the centre console, that I brought from Ebay. It looks beautiful now. I also did part of the luggage apartment floor wall, behind the seats and also rear wheel arches, with STP Black Silver. On the rear wheel arches, I have to do multiple layers (2 or 3). 2 layers of STP Black Silver and 1 layer STP LAVA. After that I will install the carpet. But before I do the luggage apartment floor, I have to make the luggage box inside the floor.
Post by Scootrific on Jan 21, 2024 17:42:50 GMT -5
Post by Scootrific on Jan 26, 2024 13:01:17 GMT -5
Post by Scootrific on Jan 29, 2024 16:57:21 GMT -5
Post by Scootrific on Jan 31, 2024 10:40:55 GMT -5
Yesterday at 8PM, I started to install the central locking system, that I brought from AliExpress, to my Aixam. Had to cut the 5 cabel ends off the driver side wires, to fit them through the small rubber hose, where the electric window and speaker wires went through. After that I soldered all the wires back together. I finished my work at 2:35am night time. But I did not get the central locking system to lock the doors I can open them, but the lock does work tough, so I need to take the door panels off again and adjust some things again, when I have the time, also I need to connect one wire to horn and 2 wires to turn signals. Second option is to buy the right central locking system, for the Aixam with lock motors.
Post by Scootrific on Feb 1, 2024 18:45:47 GMT -5
This build has a codename now ... "Project AixSound". Im planing to build, a nice custom sound system. All parts are from Hertz Mille Pro line (component speakers, coaxial speakers, bass woofer and amplifier).
Rough cost - 2794€: The sound denting - about 500 to 700€ The sound system parts - about 1307,45€ The wiring stuff- about 286,15€ The plywood for speaker boxes, amplifier and woofer case - about 500€
Post by Scootrific on Feb 3, 2024 4:31:22 GMT -5
Yesterday, I did get my central locking system to lock and unlock the doors. I had to adjust the driver side rod, what is connected to the locking mechanism. It was too tight. I need to check the passenger side too. I did try to hook the 2 pink wires, what had to be connected to turn signal light. I failed. I wanted to connect them to hazzard lights, but I broke the button, while I was removing it from the dash. I had to unplug the hazzard light button completely, because something broke inside it and I could not turn off the hazzard lights at all
Post by Scootrific on Feb 4, 2024 4:01:54 GMT -5
