thatmint240
Popping up the 2 stroke
Post by thatmint240 on Mar 17, 2024 17:51:25 GMT -5
Switched up my rollers again. Anything below 5g I lose a lot of power so I have alternating 5g and 6g rollers now which is a lot better. Can pop it up fairly easily and I top around 55mph
thatmint240
Post by thatmint240 on Mar 27, 2024 18:10:30 GMT -5
Finally got my idle jet kit in so now my dellorto 17.5 has a 105 main, 42 idle and halfway on the needle (although i may move it up one position) It rips!!
thatmint240
Post by thatmint240 on Mar 29, 2024 18:00:42 GMT -5
Made my own cheap exhaust gasket out of cardboard and high temp gaskte maker. Works well for now until i can order a real gasket. I think I MIGHT go up one more jet size to 110
thatmint240
Post by thatmint240 on Apr 4, 2024 19:26:27 GMT -5
thatmint240
Post by thatmint240 on Apr 4, 2024 19:27:03 GMT -5
Made a removable fishing rod and tackle holder for my scooter. a few friends and i are planning to go on scooter fishing trips this summer and im preparing.
thatmint240
Post by thatmint240 on Apr 15, 2024 13:59:00 GMT -5
Purchased a steering stem for Zuma Prebug from Scooter Swap Shop and it fits perfectly on my roughhouse. Also purchased some handlebars form Misguided Co the local Stunt Bike shop. Extended the wires (after I took the pictures) but I need a longer throttle cable and front brake hose. I ordered both and am waiting for them to arrive. I still havent replaced my left brake lever since it broke because im debating whether i should buy one of those RSC Finger Clutch lever sets meant for stunt bike clutch levers. I mocked one up a friend has and it would fit perfectly.
thatmint240
Post by thatmint240 on Apr 17, 2024 12:00:25 GMT -5
Post by Schlappy on Apr 30, 2024 17:13:21 GMT -5
An earlier post you said you get around 55 mph. The Speedometer on the RH is off by 10% after 20mph. The needle may say 50, but you're really not going that fast. This is intentional by design to keep kids from speeding. I've buried my needle an 1/4 inch after "50" but was only doing maybe 46 mph. A GPS speed test will clarify for sure. I'm liking the Ammo Box!
thatmint240
Post by thatmint240 on May 1, 2024 10:17:16 GMT -5
Gotcha, Appreciate that info, ill do a speed test with GPS soon and see what im getting. Its set up for wheelies rn so i know whatever it tops out at i could probably get another 10mph with the right weighting in the CVT
thatmint240
Post by thatmint240 on May 1, 2024 11:13:36 GMT -5
This is an older video i forgot to put on the thread. Have made a few changes since the video but wanted to have it in the thread.
