Post by ravensguildassasin on Jun 27, 2012 20:48:52 GMT -5
so here is what i want.
180cc to 232cc GY6 Custom Crate Engine
Brakes Used: Drum
GY6 Big Bore Options: 67mm Ceramic Cylinder and B Crankcase 100% Taiwan
GY6 Camshaft Options: Included with 4 Valve Head
GY6 Clutch options: Regular 150cc Clutch
GY6 Clutch Spring Options: Regular Clutch Springs
GY6 Crankcase Options: Long Case
GY6 CrankShaft Options: Taida 8.2mm Forged Stroker
GY6 Cylinder head options: Taida 4 large valve 23mm / 22mm cylinder head
GY6 Fan Options: Regular Fan
GY6 Final Gear: Regular Gears
GY6 Fuel / Ignition Options: NON
GY6 Intake Manifold Option: included with EFI
GY6 Magneto Options: 11 Coil Stator
GY6 Oil Cooling Options: NCY Oil Cooler
GY6 Output Shaft: Long
GY6 Roller Weights: Regular 150cc GY6 Roller Weights
GY6 Secondary Sliding Sheave Ass: GY6 Secondary Sliding Sheave Assembly
GY6 Starter Options: Chrome High Torque Starter
GY6 Torque Spring Options: Regular Torque Spring
GY6 Variator Drive Face: Regular Variator Drive Face
price is only $1,851.87USD
or if you really want to spend money.
Brakes Used: Disc
GY6 Camshaft Options: Taida T-300 Camshaft
GY6 Clutch options: NCY Racing Clutch and Drum
GY6 Clutch Spring Options: NCY 1500rpm Clutch Springs
GY6 Final Gear: 13 X 40 Gear Ratio
GY6 Fuel / Ignition Options: EFI System (tuned on DYNO)
GY6 Oil Cooling Options: Taida Oil Cooler
GY6 Roller Weights: NCY 8g Roller Weights
GY6 Secondary Sliding Sheave Ass: NCY Secondary Sliding Sheave Assembly
GY6 Torque Spring Options: NCY 1500rpm Torque Spring
GY6 Variator Drive Face: NCY Light Alloy Ventilated Drive Face
GY6 Variator Options: NCY Teflon Coated Variator
only $3,185.20USD
now to be fair this is a monster of a scooter engine the second one is just every option ticked but still. but hey you can build it however you want here. www.mbe-motorsports.com/catalog/product_info.php/cPath/19_106_104/products_id/20
what are your opinions?
Brakes Used: Drum
Brakes Used: Disc
only $3,185.20USD
