Post by ʇwiƨtɘdburnout on Apr 8, 2013 9:35:02 GMT -5
WD-40 Is NOT a lubricant! For years, I have cringed when I hear people using WD-40 as a lubricant in certain applications. This is horrible and can damage a lot of parts and devices. Simply put... WD-40 Is a WATER DISPLACEMENT spray! That's all it does, and all that it should be used for. This product gets its name from what it actually is WD = (W)ater(D)isplacement The reason it has 40 after it?.... That's because this formula was perfected on the 40th try, Hence the name WD-40. If had been on the 39th, it would be WD-39 etc... Lol! A lot of you may already know this, but If I save just one person?... well you know. Lol!
Post by usmcdoc on Apr 8, 2013 9:58:24 GMT -5
WD-40 Is NOT a lubricant! For years, I have cringed when I hear people using WD-40 as a lubricant in certain applications. This is horrible and can damage a lot of parts and devices. Simply put... WD-40 Is a WATER DISPLACEMENT spray! That's all it does, and all that it should be used for. This product gets its name from what it actually is WD = (W)ater(D)isplacement The reason it has 40 after it?.... That's because this formula was perfected on the 40th try, Hence the name WD-40. If had been on the 39th, it would be WD-39 etc... Lol! A lot of you may already know this, but If I save just one person?... well you know. Lol! You are exactly right...it is a water displacer they were working on. One Tech noted it felt slippery..so he gave a shot of it to the hinges on their lab door. It took away the squeak..so when they marketed it they added that it had lubricating qualities. You won't find it in my tool box. I lube with spray Lithium Grease...it comes out thin as water and really penetrates...then the solvent carrier evaporates and leaves a film of high quality grease..nearly as viscous as regular grease. But ya can't get regular grease into cables etc. With the lithium grease you use a cable oiler tool...the thin solvent based grease flows and wicks into your cable...then thickens up leaving a nice lubricant and corrosion barrier. I have had luck using it as Dielectric Grease BUT!! I do not advocate this. It does work for me...but I would hate for someone to fry something. As for WD-40 some use it to free locked or corroded bolts. It is borderline ok for that but still not very effective....so I always suggest PB Blaster. If that stuff won't free a frozen on bolt...your only next step is a torch...cause it is powerful stuff!!!
Post by ʇwiƨtɘdburnout on Apr 8, 2013 10:32:40 GMT -5
Yes! P.B. blaster is awesome! I didn't know about the lithium grease, I will have to pick up a can on my next trip out, thanks for the info
Post by Fox on Apr 8, 2013 10:58:19 GMT -5
It's also a penetrant for freeing up rusty nuts and bolts. WD-40 lubricates to an extent but it's not as long lasting as grease. My front door used to stay open on it's own but the hinges squeaked so I shot them with WD-40 and now the squeak is gone but the door won't stay open anymore. I have to put a shoe or something to hold it open now so it definitely lubricates some.
Lithium spray grease is the bomb! Works great on cables, brake linkage/levers, locks/key switches/seat latches. It's also good for squeaky rubber engine mount and shock bushings.
Post by 90GTVert on Apr 8, 2013 11:18:42 GMT -5
I use WD-40 if I chill/freeze a crankshaft/bearings. I also spray it on steel parts that will be stored to keep rust away, unless it's a car engine or something big. Then I tend to wipe it down with motor oil.
I've seen people use it as a stain remover.
Post by usmcdoc on Apr 8, 2013 11:47:55 GMT -5
I use WD-40 if I chill/freeze a crankshaft/bearings. I also spray it on steel parts that will be stored to keep rust away, unless it's a car engine or something big. Then I tend to wipe it down with motor oil. I've seen people use it as a stain remover. It does have good anti-corrosion properties for stored metal items. Also as you said....it works as a stain remover. Lipstick some makeups...as well as grease or oil stains on a shirt....unless of course it's white or light. For stains I use the WD-40 first...then clean the remnants of that with any of those gel like mechanics hand cleaner and degreasers..such as Goop and another called orange something?..
Post by ryan on Apr 8, 2013 19:05:42 GMT -5
Sorry folks, it appears that the 50+-year-old formulation of WD-40 remains a secret today. Any information that you may encounter alleging the disclosure of the “secret sauce” is inaccurate.
One thing we must do is correct any misinformation that may be harmful to either our consumers or our good name. Specifically, the listing of incorrect and poorly defined ingredients and safety information.
Myth: WD-40 Multi-Use Product is not really a lubricant. Fact: While the “W-D” in WD-40 stands for Water Displacement, WD-40 Multi-Use Product is a unique, special blend of lubricants. The product’s formulation also contains anti-corrosion agents and ingredients for penetration, water displacement and soil removal.
Stoddard Solvent Myth: WD-40 contains Stoddard Solvent. Fact: Over the past few decades, the name Stoddard Solvent was synonymous with all mineral spirits. Today, the mineral spirits found in products like ours are more refined and processed (see hydrogenation, hydrotreating and distillation techniques) providing mixtures with varying boiling points, cleaning ability, and chemical composition.
The catchall phrase “Stoddard Solvent” is no longer adequate to tell the proper story. WD-40 does indeed have 50% mineral spirits, but they are refined and purified for specific characteristics needed to meet today’s performance, regulatory, and safety requirements.
Health and Safety Information derived from our Material Safety Data Sheet and referred to for the general use of our product can be misleading. MSDS information is for the workplace and not primarily intended for the general consumer. For the general consumer, the product label provides the key safety and usage information.
WD-40 and Bikes Myth: WD-40 Multi-Use Product should not be used on bike chains. Fact: While WD-40 Multi-Use Product it is not a grease, it is formulated with strong lubricating oils and other ingredients, and is a terrific product to use for bike maintenance. It does not attract dirt or moisture to metal surfaces – just be sure to wipe off any excess WD-40 Multi-Use Product before riding.
For long-term lubrication and other specialized bicycle maintenance needs, check out WD-40® BIKE. Developed specifically for cyclists and mechanics, this high-performance line of bicycle care products is sure to become a mainstay in the toolboxes of bike mechanics for decades.
WD-40’s Original Founder Myth: Ken East is WD-40’s original founder. Fact: While Ken East is often referred to as one of WD-40’s original founders, he used to say, “Heck, I ain’t that old.” Ken was the facility manager at WD-40 Company’s San Diego headquarters and was affectionately known as “The Brewmaster.” He mixed up batches of our secret sauce for over 15 years and was often heard to proudly proclaim, “I absolutely LOVE my job!” Ken happily retired in 2009.
As mentioned in our corporate and brand history, Norm Larsen, founder of Rocket Chemical Company, is considered the original founder of WD-40. Read the real story behind WD-40.
What a Fish story! Myth: WD-40 contains fish oil. Fact: Consumers have told us over the years that they have caught some of the biggest fish ever after protecting their fish hooks and lures with WD-40. We believe this legend came from folks assuming that the product must contain fish oil since it appears to attract fish. Sorry Charlie®, it just ain’t so.
WD-40 Company has taken steps to respect and conserve the environment, and encourages its users to do the same. While WD-40 can be used to help protect fishing equipment from rust and corrosion, WD-40 Company does not recommend using WD-40 to attract fish.
“WD-40 Cures Arthritis!” No Way. Myth: WD-40 cures arthritis. Fact: This popular headline, appearing at least once a year in the tabloids, is completely FALSE. WD-40 Company does not recommend the use of WD-40 for medical purposes, and knows no reason why WD-40 would be effective for arthritis pain relief. WD-40 contains petroleum distillates and should be handled with the same precautions for any product containing this type of material.
Fun Facts About WD-40 A bus driver in Asia used WD-40 to remove a python, which had coiled itself around the undercarriage of his bus. Police officers used WD-40 to remove a naked burglar trapped in an air conditioning vent. Crayola® Stain Removal Tips recommends using WD-40 to remove (regular) crayon marks from a variety of surfaces. The WD-40 Book, featuring many user testimonials and the wacky humor of Jim & Tim, The Duct Tape GuysTM, was published in 1997. The familiar blue and yellow can has been featured in other books ranging from The Big Damn Book of Sheer Manliness (General Publishing 1997) and Polish Your Furniture With Pantyhose (Hyperion 1995) to WD-40 for the Soul: A Guide To Mending Everything Leslie Nielsen portrayed agent Dick Steele (a.k.a., Agent WD-40) in the 1996 movie Spy Hard. WD-40 has a Fan Club with more than 100,000 members. Join today and share your stories, get free, fun downloads, check out the eNewsletter, receive the eTip of the week, and much more... WD-40 has its own social network, the Money-Saving Tool community, where members can submit stories, photos and videos about ways to save money. As The Duct Tape Guys say, “You only need two tools in life, Duct Tape® and WD-40. If it’s not stuck and it’s supposed to be, Duct Tape it. If it’s stuck and it’s not supposed to be, WD-40 it.” So, keep using your WD-40. You can find a list of over 2,000 uses from our loyal users here. If you find a new use, please let us know. And, if you really need the secret formula, you can find it…...written on a single notepad……locked in a vault…...somewhere in California……if you can get in.
Post by moofus02 on Apr 8, 2013 19:35:14 GMT -5
Cool info
Post by Deleted on Apr 9, 2013 13:57:32 GMT -5
I have a can right here Lubricates: hinges wheels rollers chains gears
Seems to be ONLY those 5 things lol. I use it to keep rust off my guns and to remove sticky stuff.
Post by ʇwiƨtɘdburnout on Apr 9, 2013 15:32:48 GMT -5
Post by creeper on May 22, 2013 23:33:26 GMT -5
can it be used in place of dielectric grease? for like electrical connections/connectors on the scoots?
Post by bagmanoz on Jul 11, 2013 4:32:46 GMT -5
Always got a can handy.. It's great for short term lube or clean up of metal parts. I use heavier adhesive synthetic stuff for more permanent results. (CRC Tac2) and I use WD40 soaked rag to wipe guitar strings before, during, and after playing. I gig 2-3 times per week. Strings last 4-5 times longer, and fingers move easier on the fretboard. Over the years however, there's some discoloration of the fretboard due to seepage beside the frets. Always got a can handy.. Marked on the can. Contents Hydrocarbons. (=Petroleum/oil based products.) Oh and final post-wash spray on my scoot round the under bits. Looks Slick.. :-)
Post by flashback30 on Jul 11, 2013 16:08:55 GMT -5
also its great for removing pine sap or road tar off cars so sure would work on scooters as well
Post by bagmanoz on Jul 11, 2013 17:23:07 GMT -5
can it be used in place of dielectric grease? for like electrical connections/connectors on the scoots? I have done this in the past. Pull apart connector block. Scratch pins clean. Spray WD. Shake excess out. Reconnect plug. Good for at least another 18mths.
\\-olf
Iowa
Post by \\-olf on Jul 11, 2013 23:00:55 GMT -5
WD 40 does have some lubricating qualities, but the oils are so thin they quickly evaporate. I've used WD 40 for bug spray, it works extremely well on all kinds of bugs and flying insects. I remember hitting hornets with it in Oregon and watching them take off about a 45 degree climb to about 25 feet or so and then fall almost straight down dead right to the ground, LOL it reminded me of old war movies where a plane is shot down and it sputters and heads straight down.
If nothing else it makes a great bug killer and it's not toxic like RAID, and it smells decent. The little straw that comes with the can is perfect for shooting a stream at that hairy spider, cockroach, hornet, ant nest, crickets or whatever.
