Post by kevin55950 on Apr 25, 2013 0:16:47 GMT -5
I'll install the MVT when I'll get the exhaust so I have time to look at little things like this... I will need studs for this engine, stock 50cc length. I need good ones, I broke SOO much OEM ones while torquing them... a very little over tightened and BAM, they break. I was looking for long bolts but I can't find any... The Kymco I rebuilt last week was having long bolts, not studs and I like those long screws because it's easier to take the cylinder out when the engine is on the frame ( the 100cc cylinder is kinda hard to take out of my zuma if I don't take out the studs) Did you have a link for good studs and nuts? Or if you know somewhere I can find long bolts (Allen or hex). I think threads are 7X1mm. If I can't find long bolts, will these fit without breaking ? www.ebay.ca/itm/CYLINDER-STUDS-and-BOLT-KIT-for-YAMAHA-Vino-Neos-Breeze-Zuma-Zest-50cc-/280834447286?pt=UK_Motorcycle_Parts&hash=item41630997b6&_uhb=1#ht_2467wt_1002I like these taller nuts, they are less prone to get loose over time. If you have another link for similar studs nearer from US/canada send it to me, thank you ! Kevin
Post by 90GTVert on Apr 25, 2013 8:31:43 GMT -5
I have never broken 1 cylinder stud on a 2T. How much torque are you using?
rupert
Post by rupert on Apr 25, 2013 9:28:12 GMT -5
Honda Dio/Aero
Post by aznatama on Apr 25, 2013 12:57:57 GMT -5
I think 12-15 ft-lb is the torque setting per the minarelli maintenance manual. how are you breaking those bolts??
Post by kevin55950 on Apr 25, 2013 14:08:59 GMT -5
I tighten them at 10-12NM as it should (from my CY50 manual), but they break when I tighten them OR they break when I crank the engine, I hear pressure escaping from the cyl. head ( engine at idle) and when I re-torque them, one has broken...
I've seen Kymco, Aprilia etc. where the cyl. head bolts were tightened far over this and the studs/bolts don't break ( I had to take 2 wrench together to loosen them). It looks like they get weaker after some time... I really don't want this to happen on the LC. I only have studs that were on 30K+ km engines. I need new ones, and I don't want to buy cheap studs that break easily.
Post by 90GTVert on Apr 25, 2013 14:23:59 GMT -5
I see why you're looking for better studs now. That's just less than 2/3 the torque I put on mine. Might wanna get your tq wrench re-calibrated. I'm just using stock CPI studs (Keeway, Vento) on the 50-70cc and I buy stock replacement studs from 90cc ATVs from kaseaparts.com for the strokers.
Post by aznatama on Apr 25, 2013 17:53:20 GMT -5
These tq setting are really low... I can pretty much tq them w/ a 1/4" tiny rachet.
Not sure how under-torquing it would cause them to break. I can understand overtorquing them, but will undertorquing them break them too?
Post by kevin55950 on Apr 25, 2013 20:11:59 GMT -5
They break if I over-torque them a little. As I told they come from kinda high mileage engines so it might be the cause, I just don't want to buy studs that will do the same lol.
Post by 190mech on Apr 25, 2013 20:23:47 GMT -5
Ive never had studs break either!Use the proper torque for your engine with a GOOD torque wrench!!I have found that 90cc plus builds do tend to leak at the head some,but I think its due to the very weak crankcase design our scooters have..
Post by kevin55950 on Apr 25, 2013 20:42:25 GMT -5
I ordered the studs I sent the link on the first post. I hope they'll last lol. I'll try to find a good torque wrench, at local stores they are only 40 NM+ models.
