what can cause engine to bog Feb 1, 2014 16:57:19 GMT -5 Quote Select PostDeselect PostLink to PostMemberGive GiftBack to Top Post by 90GTVert on Feb 1, 2014 16:57:19 GMT -5 As long as whatever you use is good for gas and you check the squish it should be OK. Some gasket materials compress a lot so you may want to check once it cools done from the first ride as well.
