Post by cobra71 on Mar 29, 2014 21:06:26 GMT -5
i have a 2010 tao tao 50cc fourstroke it has 140lbs of compression.plenty of fire and even if u spray gas in cylinder it will not start i have checked the compression several times with 2 different gauges i know it is in time and the valves are adjusted right this one has me stumped.ANY HELP IS GREATLY APPRECIATED.
Post by kkzxxx on Mar 30, 2014 6:06:45 GMT -5
air leak between carb and cylinder?
Post by 90GTVert on Mar 30, 2014 7:40:26 GMT -5
Welcome to the forum.
If you happen to have another CDI around, swap it. Gas isn't old?
Post by cobra71 on Mar 30, 2014 9:53:13 GMT -5
it has a new intake,spacers and o rings when it was running i sprayed starting fluid around the intake several times no change in rpms the cdi i used is good it came off of another scooter that runs fine with no problems at all.i cleaned the tank and i am using fresh gas.thanks for all the suggestions.
Post by moofus02 on Apr 1, 2014 12:55:20 GMT -5
sheered key on Flywheel knock timing off?
Post by cobra71 on Apr 20, 2014 14:10:11 GMT -5
thanks for all the help i got it to fire up and run for a second but went dead it was to much trouble so i sold it.
