Post by kevinstaykushed on Apr 11, 2014 2:17:44 GMT -5
So, my scooter will start but it wont stay idle, ill drive it around and as soon as I stop it cuts off and itll take a while to turn bacc on. And also when I ride it, it will slowly start to bogg out and eventually cuts off. I have no speed anymore. I replaced the carb thinking that was the issue but its not. Somone please help me. I have no clue what I am doin and I want to learn since noone has helped.
Post by usmcdoc on Apr 11, 2014 5:56:47 GMT -5
So, my scooter will start but it wont stay idle, ill drive it around and as soon as I stop it cuts off and itll take a while to turn bacc on. And also when I ride it, it will slowly start to bogg out and eventually cuts off. I have no speed anymore. I replaced the carb thinking that was the issue but its not. Somone please help me. I have no clue what I am doin and I want to learn since noone has helped. Is it a 4 stroke? If so..have you checked and adjusted your valves? What you describe is a classic symptom...slow and gradual loss of power..then shutting off and difficult to restart.. Check those first. Then tell us what ya found..
Post by kevinstaykushed on Apr 11, 2014 11:52:42 GMT -5
Maaaaaan thanks for the help!!! I did the valve adjustment and my scoot runs like a champ now! I been tryna fix this damn thing for two months. Took me 7 buccs and 10 mins thanks to your help.
Post by usmcdoc on Apr 11, 2014 12:53:22 GMT -5
Maaaaaan thanks for the help!!! I did the valve adjustment and my scoot runs like a champ now! I been tryna fix this damn thing for two months. Took me 7 buccs and 10 mins thanks to your help. You are more than welcome! That is what we are here for correct??...To help each other. Your thanks should also directed at 90GTVert (Brent).. for he is the one who started and manages this site.. He is that magical mystery man behind the curtain.. Without him giving us the opportunity to be members..we would not have had the opportunity to assist you. Btw..what gap did you set your valves at? Hopefully you were able to find the super easy tutorials on here to guide ya. The Tech section is LOADED with problems and their solutions and some helpful tips and kewl projects as well. Also...
Post by kevinstaykushed on Apr 12, 2014 13:57:24 GMT -5
Umm I went and bought fuller gauges and set then at .003. Also when I ride for a period of time my scooter will completely jus cut off on me.
Post by flqu06 on Apr 12, 2014 18:32:43 GMT -5
Pull off the fuel line going to the carb when it dies ansd see if anything comes out. There should be a small amount left in the tube.
Post by usmcdoc on Apr 12, 2014 18:42:24 GMT -5
Umm I went and bought fuller gauges and set then at .003. Also when I ride for a period of time my scooter will completely jus cut off on me. Carry a spare plug with you..and the minute it cuts outs pull the plug wire and push the spare plug in it..then ground it to frame and crank the engine looking for spark. Sometimes when the pickup coil gets hot they stop working..and you get no spark. ALSO do as flqu06 mentioned above...if it is a fuel delivery issue such as a bad vacuum petcock..you may lose fuel flow and like he said some should still dribble out. You can leave the carbs fuel inlet line off then pull the vacuum line from the intake manifold..give it a few gentle sucks(vacuum line) and fuel should flow. If not the vacuum petcock is bad. If it does flow when you suck on the vacuum line..your float height may need to be adjusted. Also VERIFY your valve lash setting..it may have loosened and become too tight again. Try those..then let us know..
Post by kevinstaykushed on Apr 15, 2014 13:49:10 GMT -5
If I ride it for a long distance I jus cut it off when I get to a red light until its green.
