Post by oldsman on Apr 16, 2014 1:47:56 GMT -5
I am thinking of doing some body mods and some electrical mods. I want to build a better front faring for a handsome boy and want to try an aftermarket ign system. I have a MSD 6al sitting here brand new and thought I might try it. Going with an automotive COP for a better spark. Any thoughts?
Why would you do this, you ask? Why the hell not.. Its diffrent and I sitting here at this comp and looking at my to-do-must-try list.
Post by craisin on Apr 16, 2014 4:08:44 GMT -5
Post by craisin on Apr 16, 2014 4:11:26 GMT -5
oh it draws 7amps per 1000rpm
Post by Grom Reaper on Apr 16, 2014 9:23:16 GMT -5
i'm right there with you buddy! I'm currently running my rat project scoot on a 2002 crown Victoria ignition coil. Been using it for almost a year now and no problems!!!
Post by Sitticuss on Apr 16, 2014 9:26:36 GMT -5
Build your own... Ride it hard...Die free
Post by Grom Reaper on Apr 16, 2014 9:39:55 GMT -5
Post by 90GTVert on Apr 16, 2014 10:42:38 GMT -5
oh it draws 7amps per 1000rpm 0.7A per 1,000RPM... still that's gonna be 4-6A @ cruise at that rate and near 7A max. I don't know that that figure would be correct for a single cylinder though. This is just an assumption, but I'd guess that's probably a figure for a V8 since so many 6A boxes are sold for V8s. Could be wrong, but continuing on with that logic if you take 0.7A and divide it by 8, then each cylinder would require about 0.0875A per 1,000RPM. If the trigger is still setup the same, these engines are wasted spark so they actually fire once on every revolution instead of every other revolution. Then I assume you should double the single cylinder number of 0.0875A per 1,000RPM and it becomes 0.175A per 1,000RPM. Using that figure, cruise RPM would likely be 1-1.5A which is just about the max a typical charging system will support without really draining the battery. Of course that's all just assumption and I may be 100% wrong. I have ran the 6AL, 6-BTM, and Digital 6 before and I do know that when the battery got low from an alternator issue the car sounded like I had the two-step on and would barely get out of it's own way, so a good power supply may be a concern. I know you probably don't have one lying around, but this is probably what I would be looking at if I wanted to use an MSD product on my scoot... www.summitracing.com/parts/msd-4217
Post by craisin on Apr 16, 2014 11:08:50 GMT -5
oh it draws 7amps per 1000rpm 0.7A per 1,000RPM... still that's gonna be 4-6A @ cruise at that rate and near 7A max. I don't know that that figure would be correct for a single cylinder though. This is just an assumption, but I'd guess that's probably a figure for a V8 since so many 6A boxes are sold for V8s. Could be wrong, but continuing on with that logic if you take 0.7A and divide it by 8, then each cylinder would require about 0.0875A per 1,000RPM. If the trigger is still setup the same, these engines are wasted spark so they actually fire once on every revolution instead of every other revolution. Then I assume you should double the single cylinder number of 0.0875A per 1,000RPM and it becomes 0.175A per 1,000RPM. Using that figure, cruise RPM would likely be 1-1.5A which is just about the max a typical charging system will support without really draining the battery. Of course that's all just assumption and I may be 100% wrong. I have ran the 6AL, 6-BTM, and Digital 6 before and I do know that when the battery got low from an alternator issue the car sounded like I had the two-step on and would barely get out of it's own way, so a good power supply may be a concern. I know you probably don't have one lying around, but this is probably what I would be looking at if I wanted to use an MSD product on my scoot... www.summitracing.com/parts/msd-4217I got that figure off the link i put up click on Specifications be a blast if you have the power
Post by craisin on Apr 16, 2014 11:15:42 GMT -5
there is a downloadable PDF File on the link as well
Post by FrankenMech on Apr 16, 2014 11:51:07 GMT -5
Try anything! It is all fun.
Post by Grom Reaper on Apr 17, 2014 19:36:03 GMT -5
Here's another home made crazy mod I came up with. Alcohol injection, or for gas spray to even out the nos dry shot(clear tube in the back) I'm still tuning it in though.
Post by FrankenMech on Apr 17, 2014 21:30:54 GMT -5
Here's another home made crazy mod I came up with. Alcohol injection, or for gas spray to even out the nos dry shot(clear tube in the back) I'm still tuning it in though. Dear God... Why not just use nitro-methane.... BOOM!
Post by FrankenMech on Apr 17, 2014 21:32:17 GMT -5
Holy crap! I probably just gave you another idea!!!!! -Yikes!
Post by oldsman on Apr 18, 2014 12:14:13 GMT -5
Holy crap! I probably just gave you another idea!!!!! -Yikes! damn sure did
Post by FrankenMech on Apr 18, 2014 14:04:25 GMT -5
I have had that idea wandering around. After all, these are just giant scale model aircraft engines.... That nitromethane fuel is only $25-35/gallon.... Think of the POWER!
Then add NITROUS!
