Post by rickyrod on Apr 17, 2014 20:28:19 GMT -5
hey guys. i have a 50cc roketa scooter. it's fairly new only 650 miles on it.
recently it has been giving me a problem. when i ride it at full throttle the engine loses power for like a split second or two and then gets back in gear. it feels like it randomly switches to a lower gear and then comes back up. its the same feeling of going full speed and letting go of the gas. so it kinda jerks me forward since im not expecting it. this only started happening a day ago so i really dont want to ride it and mess it up even more. any ideas what may be causing this and what i should do? thanks guys.
Post by dan50 on Apr 18, 2014 0:44:25 GMT -5
Check the fuel pump, fuel filter and fuel lines. Kinda sounds like gas isn't keeping up with the engine. Also check the float level in the carb. Might be adjusted too low and running sorta dry.
If the fuel checks out, it might be the coil or CDI.
Post by 90GTVert on Apr 18, 2014 8:30:55 GMT -5
If it happened just after a fill up, you could have got bad gas. Make sure all of the fuel and vacuum connections are secure and no hoses are cracked.
Post by rickyrod on Apr 18, 2014 12:02:31 GMT -5
thanks! I'll look into that.
Post by rickyrod on Apr 19, 2014 23:59:14 GMT -5
checked the gas lines, they all look good to me. and got a fresh tank of premium gas. its getting worse. it lost power for like 5 seconds while i was riding from work. im thinking about taking it apart. what should i replace?
Post by Upgrayedd on Apr 20, 2014 0:01:27 GMT -5
checked the gas lines, they all look good to me. and got a fresh tank of premium gas. its getting worse. it lost power for like 5 seconds while i was riding from work. im thinking about taking it apart. what should i replace? have you checked your spark plug to see how it looks?
Post by rickyrod on Apr 20, 2014 0:04:47 GMT -5
i have not. what should i be looking for on it?
Post by Upgrayedd on Apr 20, 2014 0:08:59 GMT -5
Post by rickyrod on Apr 20, 2014 0:12:01 GMT -5
ok thanks. ill check that out tomorrow. im really hoping it's something simple cause I've only had this bike for 2 months. thanks for the advise, very appreciated.
Post by Upgrayedd on Apr 20, 2014 0:20:30 GMT -5
ok thanks. ill check that out tomorrow. im really hoping it's something simple cause I've only had this bike for 2 months. thanks for the advise, very appreciated. no problem. you may find no problems, if nothing else then you can rule that out.
Post by JEGZ on Apr 20, 2014 22:10:30 GMT -5
You could have something wrong with the carb needle check to see if the slide is fully retracting smoothly.
