casedaddy49in
Scoot Junior
Life is what ya make of it, so do something!!!!!
Post by casedaddy49in on Apr 18, 2014 15:54:48 GMT -5
Hey everyone ive been busy today working on the scooter because of some starting problems..I just received my new carb in the mail thinking that would solve all my problems..But it still wont start..ive put a new battery and spark plug in recently as well..So I'm stumped and looking for some input on what ya think..heres the video NO START
Post by ososlow on Apr 18, 2014 16:01:14 GMT -5
sounds to me like either the starter is bad or the gear (bendix?) is outta alignment with the variator. try taking a long 13mm wrench or similar size and tapping on the starter while you try to crank it
casedaddy49in
Scoot Junior
Post by casedaddy49in on Apr 18, 2014 16:11:48 GMT -5
I just went out and tried and still not working..thanks for the tip..
Post by Sitticuss on Apr 18, 2014 17:23:35 GMT -5
Pull the cvt cover off and inspect the starter and gears etc. JUmp a wire from the plus side of the battery to the plus side of the starter while you are looking into the cvt and see what is happening
Post by ososlow on Apr 18, 2014 17:23:49 GMT -5
np try taking off the cvt cover and checking the starter gear im pretty sure you can wiggle it outta there without removing the variator and grease the bushing
nightriderrv
Never Give Up- Ride all the time !!!!!
Post by nightriderrv on Apr 19, 2014 10:34:19 GMT -5
A weak starter will sound like that, also a performance CDI will make it hard to start and will give that same sound so that's 2 areas to look at will it kick start at all..
Blowin Smoke
Post by Blowin Smoke on Apr 23, 2014 16:48:04 GMT -5
Lets start here: Does it crank? Do you have spark? Is the kill switch on? You have to give more specific info or tell us you don't know, we can work with that. You have to start with what does it do what it doesn't do being specific if you can.
