Post by bclivewire on Apr 19, 2014 19:34:26 GMT -5
ok I have a 2005 zuma 50cc reringed
modded are pipe and 19mm carb with 90 mail jet (stock air box with snorkel removed
after 1/2 mile or less it seams like it is running out of fuel
I back out of the throtel with in 2 maybe 4 secens it will come back to live
im runung the stock vacuum petcok
is there aney way to keed the stock petcock?
I haavent tried the open fuem cap trick to see is there is a vacuum in the tank....
Post by 90GTVert on Apr 20, 2014 13:57:16 GMT -5
I'm really not a fan of stock petcocks, so I'd ditch that but I don't know that you have to. Try the fuel cap trick first.
Could be the float height is set a little low and you're running out of fuel. Lines and filter look good?
Post by bclivewire on Apr 20, 2014 21:30:55 GMT -5
hhooo float settings .... thank you I would not thot of that
this is way I like this forum
let me check that to
Post by bclivewire on Apr 21, 2014 17:34:55 GMT -5
ok that is good info
but onn the zuma the petcock paced over the rear tire
it would be nicer to mave it to a more conveut pace
rupert
Post by rupert on Apr 21, 2014 18:02:58 GMT -5
I *think* you are kinda "caught" though. The petcock should mount to the tank with a couple of screws through a kind of triangular metal bit, the only thing I could find to replicate that is a petcock off of a Raptor. You simply trim (or cut) a hole in the inner fender to let you deal with it, you do get the bonus of a "reserve" position, if for some reason you do away with the fuel gauge.
Post by bclivewire on Apr 22, 2014 9:58:27 GMT -5
well I added lot od oil to the gass (note still running oil injction)
than blasted compreced air thoew the tank vent .. no issues there
Post by bclivewire on Apr 22, 2014 19:50:48 GMT -5
well im going to run the tanj out than modd the stock petcock but drillind out the ports to inprove fuel flow
Post by bclivewire on Apr 23, 2014 13:45:51 GMT -5
ok I have rum 10 gallen of gas throw my scooter but the oil is not going down
and whin I add oil to the gass it runs far stronger
I will try the 2nd oil pump next
ps this scooter has no oil smock at all
Post by moofus02 on Apr 23, 2014 23:01:10 GMT -5
My 08 doesn't smoke. Unless you know something I don't you can't see the oil level in a Zuma all I can do is add to see how much I've used until the light comes on. 10 gallons at 40:1= 1 quart of oil roughly. Have you added to see how much it took to top off? If it wasn't getting oil it would seize. I've got around 4000 miles on mine and have not gone through 1 gallon of oil yet not counting what the dealer put in to get me home. 10 gallons of gas is like 600 miles if you aren't using oil you are in trouble
Post by bclivewire on Apr 24, 2014 3:12:04 GMT -5
well furst off my side body work is removed do to the furst owners braking off all the mounting tabs
so I can see that little to none of the furst quort of oil has been used
as for my MPG it id under 50mpg by a long shot
is the aney type of mecherment for the oil injection?
like iedel for 3minnets get 3cc of oil out ?
Post by bclivewire on Apr 24, 2014 14:36:25 GMT -5
got oil ... let it run for a minnet or 2 got 1 drop of oil every 20secnts
so pulling the carb next to ajust flote
Post by 2stroked on Apr 24, 2014 15:21:56 GMT -5
These oil pumps r made 2 put out the exact amount of oil the motor needs at any given throttle position all of the time. You wont see much oil leaving the tank. Only a drop every couple of .minutes or so.
Post by 2stroked on Apr 24, 2014 15:34:04 GMT -5
well furst off my side body work is removed do to the furst owners braking off all the mounting tabs so I can see that little to none of the furst quort of oil has been used as for my MPG it id under 50mpg by a long shot is the aney type of mecherment for the oil injection? like iedel for 3minnets get 3cc of oil out ? Yes u can adjust the pump if it is the type that has a cable running from the throttle. U can see how here 49ccscoot.proboards.com/thread/3151/avoiding-soft-seize-pump-adjustmentThank you usmcdoc, for posting this vital information, here and elsewhere
