Post by scootlife on Jun 7, 2014 15:40:42 GMT -5
I just put in a hd stroker crankshaft to help support my 100cc bbk and other upgrades. I have an A9 camshaft, 19mm carb and 50mm head. Since I put on the crank, I've been having what I can only describe as a heavy vibration. I can feel it through the seat and in my handlebar assembly. I have 6.5gram variator weights. I get to about 8000 during takeoff then it stays around there until 42 mph or so GPS verified. Any ideas or experience with a vibration like this? It is not my brakes, axle or axle bearings. Feels more engine related. Maybe it is normal with the new crank and bbk, but just wanted to get some feedback. Thanks!
SCOOTLIFE
Post by scootlife on Jun 8, 2014 5:25:50 GMT -5
Tough question I guess.
Post by craisin on Jun 8, 2014 7:32:57 GMT -5
Post by 90GTVert on Jun 8, 2014 10:26:09 GMT -5
You could try removing the variator and running it up to RPM on the center stand to see if the vibration is still there. If it disappears with the CVT disengaged you may need to look at the CVT components, gearbox, and wheel/tire. If not, make sure it doesn't look like your crank is spinning out of round.
Post by iwiketuddlz on Jun 10, 2014 13:12:21 GMT -5
Could be your crank is not balanced I have had the same problem with a brand new crank had to return it. Also could be your rollers are not equal,check the weight of them
bert
Scoot Junior
49 cc taotao front mount cant find out what they call it.i know the back 2 they have bushings.
Post by bert on Jun 20, 2014 12:08:25 GMT -5
49 cc taotao replaced 1 out of 4 motor mounts still vibrates the front i cant make out it looks like a rubber bushing dont know what it is called? its mounted to the bracket with the motor mounts. any one know? it goes to the front.
Post by scooterpimp on Jun 20, 2014 13:19:48 GMT -5
Problem started after you installed new crank. Am I missing something here? ?recheck your install , flywheel , variator , etc. Then suspect wompussed crank?
Post by stevec on Jul 7, 2014 20:09:07 GMT -5
crank is unbalanced, is it a cheapo chinese crank or a taiwan like NCY or Hoca? the larger stroke cranks work best with the 52mm pistons, it is more balanced for weight vs the 50mm piston.
Post by scootlife on Jul 9, 2014 19:56:43 GMT -5
It's a Naruka 44mm HD crank. $149. It sounds like it was good quality.
Post by stevec on Jul 12, 2014 6:41:41 GMT -5
Naraku does make good quality. when you installed the crank did you tap it into place or did you heat the block and cool the bearing on the crank?
Post by scootlife on Jul 12, 2014 10:03:30 GMT -5
I did the cold hot method.
SCOOTLIFE
Post by scootlife on Jul 12, 2014 10:04:08 GMT -5
I've actually just kind if got used to it. Not that noticeable anymore
SCOOTLIFE
Post by stevec on Jul 13, 2014 5:43:01 GMT -5
Most chinese scooters vibrate anyway so if it is not bad i wouldn't worry. if it is enough to vibrate stuff loose i would try to balance it. mine is the only china scoot i ever rode that didn't vibrate, feels like a Harley idling but no vibration moving.
